04-22-2005, 12:44 PM | #1 |
Member#: 83444
Vehicle:2005 STi Blue w/Gold Rims |
Auto "UP" mod for power windows..???
Is there an auto-up feature that can be hacked into the switch....on DSm's there is a resistor that can be soldered into the switch to do this...Anyone heard of such a thing?
Dave
04-22-2005, 12:48 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Not for Subarus. The auto-down function is part of a circuit board that incorporates the driver side window and lock switches, it's not something that can be modded. The only way to add additional auto-up or -down functionality to the windows is with aftermarket alarm system modules like DEI.
04-22-2005, 03:30 PM | #3 |
Member#: 47769
This is most definitely a long shot and I am in no way saying this will come remotely close to working, but may be worth the look.
http://www.vfaq.com/mods/auto-up.html This is for a 1G Talon. Again, no idea if this can be any use in any way. |
04-22-2005, 03:39 PM | #4 |
Member#: 16980
The problem with the auto UP function on cars is that it needs a "load sensor" on the motor that drives the window up in case there is something in the way,
try a car that has auto up and put your hand in the way, you will see that the window will stop going up. this is somethign to look into if you are going to implement this system ... which is probably the reason we dont have the system ... its costly and this was something subaru saved money on. this is really something subaru should look into if they are thinking about goin "Premium" |
04-22-2005, 04:26 PM | #5 |
Trust no one
The Subaru setup is nothing like the Talon in that link.
04-22-2005, 04:42 PM | #6 | |
Member#: 47769
04-22-2005, 08:00 PM | #7 |
Member#: 24888
Vehicle:2016 Outback Limited |
Buy a Loyale
....but we don't have those fancy sensors that stop the window if you shove your little brother's head in the way.... |
04-23-2005, 05:58 AM | #8 | |
Member#: 8023
Vehicle:2019 Crosstrek white |
04-23-2005, 04:09 PM | #9 |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! White |
There are also stand-alone modules (for one window and maybe also for a pair) made by companies like Autoloc. I installed one on my Miata driver's side window to get auto-up and auto-down. One module is about the size of a pack of cigarettes and gets wired between the OEM switch and the window motor. When it senses the switch being held down or up, it activates the "auto" feature. The module also supplies the higher-current power to the window motor, so it can sense when the window has hit an obstacle or is binding, and shuts off the power in that case. It takes a bit of automobile electrical wiring knowledge to properly install it, and it cost about $50/module IIRC.
Auto down power window mod? | MinesPunk | Electrical & Lighting | 4 | 11-26-2009 12:34 PM |
scamatics for power window swap | nwvw21890subaru | Subaru Conversions | 2 | 03-02-2008 08:14 PM |
power window full auto 4 windows | asianboy101 | Electrical & Lighting | 5 | 11-10-2003 06:11 PM |
what kind of lubricant should I use for power windows? | yuusaku | Interior & Exterior Modification | 1 | 06-04-2001 06:50 PM |
Auto Power Windows | Rez | Technical Forum Archive | 12 | 08-15-2000 06:26 AM |
