Old 04-23-2005, 12:41 AM   #1
Soulofdarkness
Member#: 83637
02 WRX PSM
And "Infamous Car #2"
Default Cobb Accessport and Air Intakes
Ok I'm looking to get the Cobb Accessport very soon (ie. end of month if not sooner). And I got a AEM Short Ram Intake for my '02 WRX. When I E-mailed cobb they said they stoped supporting Accessport with aftermarket intakes. So I was wondering how bad it would be to run accessport with my air intake. Any help would be greatly appreacated.
::Puts on flame suit and jumps in to the oven::
Soulofdarkness is offline   Reply With Quote
Old 04-23-2005, 12:50 AM   #2
andrew12
Member#: 67787
2012 WRX limited
SWP (military green soon)
cobb makes maps for the accessport for the injen cold air intake so... I am confused by them saying they dont support aftermarket intake.
chile
andrew12 is offline   Reply With Quote
Old 04-23-2005, 12:53 AM   #3
flyKen74
Member#: 82092
04 very slow WRX
Dirty PSM
just get rid of that aim intake,, either AP or not,,it isn't the thing for Rex,,
flyKen74 is offline   Reply With Quote
Old 04-23-2005, 12:56 AM   #4
Soulofdarkness
Member#: 83637
02 WRX PSM
Yeah it confused me too. Because on there website they contradict themselves about the intakes, then all I ask is if they would change the diameter of the area around the MAF and this was there response...
"Adam,
I am sorry we don't supply mapping for aftermarket intakes any more. Their inconsistency makes it difficult to provide an off the shelf solution for them.
Cheers,
Justin
COBB Tuning"
So... Yeah... Any ideas?
Old 04-23-2005, 01:55 AM   #5
skubie209
Member#: 73249
03 WRX 4EAT
I believe the reason they have the map for the injen cold air is because they had a car on the dyno a while back that had that intake and played around with it for a while and were able to get a decent tune out of it w/o the usual discrepencies that you get when trying to tune with an aftermarket intake. It would be a waste of their time and money for them to buy an intake system from every manufacturer out there and have to spend hours upon hours of dyno time to try and tune for each particular brand intake. I had an aem cai on my 03 wrx with cobb stg 2 setup and well, lets just say that was a very bad idea. Point being, put the stock intake back on or don't run an ap. The aftermarket intakes cause nothing but problems when trying to tune our cars. At least that's what I've been told by cobb and vishnu.
skubie209 is offline   Reply With Quote
Old 04-23-2005, 02:55 PM   #6
scooterforever
Member#: 55011
Take a look at Unabomber's intake FAQ. The stock intake is actually pretty good. Cobb has a very short list of maps for alternative intakes. Other off the shelf tuners have zero support for any non-stock intakes (e.g., Vishnu). The issue is, they don't add any power until you get substantially beyond stock, and they can distort MAF readings, which can lead to blown engines, etc.
scooterforever is offline   Reply With Quote
Old 04-23-2005, 03:10 PM   #7
STI_VT
Member#: 66352
2004 STI
WRC Blue
I asked them about having a typhoon intake on my STI and they said they dont reccommend using AP with intake, but if you want to put your car on their dyno then they will tune it.
STI_VT is offline   Reply With Quote
Old 04-23-2005, 04:13 PM   #8
Soulofdarkness
Member#: 83637
02 WRX PSM
Hmmm... Where are the located and how much would it cost to get it tuned. If any one knows that is...
Old 04-23-2005, 05:03 PM   #9
rustyzipper
Member#: 79175
2004 FXT
Red
get rid of it, had one with the AP and it screwed all kinds of things up , stock box with the delete is the way to make Cobb happy, you'll lose that cool sound for the most part , but you wont idle like crap and throw lean codes p0171 etc.
rustyzipper is offline   Reply With Quote
Old 04-24-2005, 03:37 PM   #10
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
neanderthal blackout
i talked to cobb about typhoon when typhoon first came out and they said they'd just dyno'd an sti with one and it did "ok". since then, they've been telling people not to use it.
i've had a typhoon for nearly 17,000 miles with both ap stage 1&2 93. it has never burped once and the increase in hp at the upper end is obvious. dataloging has shown that it is (quoting nhluhr) "the perfect emulation of the stock box." it is one of the best first mods you can do imo.
i'm a big fan of cobb but they have been totally transparent in their obnoxious efforts to discourage sti owners from buying typhoon for no other reason but to hold them off until they release their own intake.
MeetMrGlock is offline   Reply With Quote
Old 04-24-2005, 04:22 PM   #11
hondaeater69
Member#: 60324
There are intakes that will work without retuning, but you need to have the tools necessary to make sure it isn't hurting your car. Eg, OBDII, EGT, AFR and knock sensors. Cobb is saying that because there are a lot of half ass intakes on the market that will seriously mess with your tune. They're not going to recommend ANY intake that they haven't EXTENSIVELY tested on their own dyno across a broad range of cars, conditions, and variables.
Old 04-24-2005, 04:35 PM   #12
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
some will.
typhoon won't.
cobb knows it.
(if they don't they should.)
Old 04-24-2005, 05:12 PM   #13
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Originally Posted by MeetMrGlock
some will.
typhoon won't.
cobb knows it.
If it doesn't mess with the tune, they why bother with it?
I've seen very high injector duty cycles with the stage 2 map for a wrx. Using a larger intake could push these even higher. That wouldn't be a good thing.
Mike
crazymikie is offline   Reply With Quote
Old 04-25-2005, 10:15 AM   #14
rexorama
Member#: 25912
03 MBP Sedan
02 PSM Wagon
Intakes are a waste of money on mildly modified cars. There is no need to replace the stock box. Drop in a Perrin or K&N filter and be done. The stock box can support 300WHP, worry about replacing it after you hit that number.
rexorama is offline   Reply With Quote
Old 04-25-2005, 10:29 AM   #15
subieworx
Member#: 47769
Not trying to sound mean here, but seriously people open your eyes. There are new intakes coming out for our cars that are not causing problems and are giving true and safe HP gains. Just because intakes of the past were not necessarily good does not mean intakes of the present and future are the same way. It is the way if evolution.
I have heard of many STi and some wrx owners running stage 2 AP's and the Typhoon intake and have had no problems. SOme have even dynoed an additional 12 whp using that intake with the stage 2 AP and no negative effects on IDC or A/F ratios.
subieworx is offline   Reply With Quote
Old 04-25-2005, 11:14 AM   #16
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
it dosn't mean that they are any better either
the intakes the don't cause the proublme "shorty" suck hot air from inside the engine bay - yay just what you need
there is only 1 reason to have an intake .. a FMIC after which you need a tune any way
Old 04-25-2005, 12:44 PM   #17
subieworx
Member#: 47769
Again, the old school of thought that does not want to accept the possibility of change.
Old 04-25-2005, 05:28 PM   #18
dosage0
Member#: 42323
2004 WRX
Silver - UTEC, Tuna, TBE
Its not that there isnt a possibility of change, or that certian intakes could possibly provide gains. The point is that some of the most respected and popular tuners often say not to use them. They would probably know more than someone who throws an intake on their own car and decides its fine because their particular car hasnt had any problems.
I don't have an opinion one way or the other personally. I just think that the major benefit to an intake is that they lean out the fuel mixture on stock cars. That will give you a HP increase and will still remain safe because you are dealing with a stock car that has fuel safety built in. If you use an accessport or UTEC or what have you, you are leaning the car out electronically. The intake now A) Is pretty much made obsolete because all it does is duplicate what the AP/Utec/Hydra/Ecutek is doing and B) Possibly can cause problems because now the engine management has taken the safety margin of fueling out.
Bottom line is that many of them are a bitch to tune for because if they throw the MAF off even a tiny bit, the A/F will be wrong.
two cents
Rob
dosage0 is offline   Reply With Quote
Old 04-25-2005, 05:37 PM   #19
subieworx
Member#: 47769
Agreed, but there are some new intakes that do more than just "play" with the MAF signal and through their desiogn are creating power by more efficiently allowing air to enter the engine. There are many intakes out there that are not safe for the cars which is where most of the bad reputation of intakes originates. WHat you say about tuning and intakes also makes sense, however given the general level to which Cobb tunes the AP maps there is the possibility that for many people an intake that creates gains based on efficiency of design would work well with their AP setup and not cause any damage.
Tony
This could probably be debated for quite some time.
Old 04-25-2005, 07:10 PM   #20
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Tony
Assuming what you say is %100 accurate (which I doubt personally, but...) how do you decide which ones work and which don't without spending thousands in dyno time? Then how do you tell customers without confusing them, or pissing off vendors who you have not yet tested? Then, once we get past all that, how much additional performance are you getting over stock for all of that money spent?
bofh is offline   Reply With Quote
Old 04-25-2005, 09:17 PM   #21
rexorama
Member#: 25912
03 MBP Sedan
02 PSM Wagon
It has nothing to do with old school not wanting to change, it has to do with the stock box flows fine and provides air for at least 360-370 CHP, so why waste $120 plus on something that only gives you 5 hp IF you can tune for it. Regardless of if your car does not throw a CEL, it does not mean you have made power. Great, you can flow more air to the engine, but without retuning, cams, increased boost pressure, larger displacement, or larger turbo just what exactly do you think is going "suck" more air in? If the stock stuff isn't a restriction, you haven't accomplished anything.
Old 04-25-2005, 09:47 PM   #22
subieworx
Member#: 47769
How did "others" decide that the intakes currently on the market we not good? They spent lots dyno time figuring it out.
What really interests me though is why everyone is so close minded about it. I'm going to stop trying to figure it out. In a year if it is more of a respected practice we'll revisit this discussion.
Old 04-25-2005, 10:02 PM   #23
seattle944t
Member#: 18308
2005 WRX STi
Because it (K&N Typhoon on an STi) adds 13hp peak at the wheels, and from 5hp to 10 everywhere else starting @ ~4250RPMs, with the same pig rich AFRs (low 10s) as stock and cobb stage 1 , W/O any tuning/learning on a mustang dyno.
So yes, the stock box is restrictive. Not totally a choke point - but the intake is worth a 5% increase at the wheels at Cobb stage 1 levels. Hardly worthless.
seattle944t is offline   Reply With Quote
Old 04-25-2005, 10:25 PM   #24
rexorama
Member#: 25912
03 MBP Sedan
02 PSM Wagon
Do you have a dyno sheet to prove this? A dyno sheet from your testing or someone reputable?
This discussion is about an 02WRX, look at the first post, not an STI. There's a bit of a difference between a VF39 and a TD04 and 2.0 liters to 2.5 liters last time I checked. On an 02 WRX, an intake is not worth the $250 plus (for a typhoon since you made that call) when you would be better off spending that dough on a VF34 or the like first. That is the point to what I'm saying, so don't take it out of context and compare an STI to a WRX.
Old 04-25-2005, 10:30 PM   #25
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
so with the regular wrx's running 2.5 w/ a vf30/vf34, will the typhoon add any gains? the sti runs the vf39 and seems to get some extra power from the typhoon. why the difference?
anthonyrb98 is offline   Reply With Quote
FS: Cobb turboback, ssac tmic, cobb accessport, and cobb springs wrx/zzr Engine/Power/Exhaust 15 09-13-2006 02:33 PM
Cobb Legacy Cold Air Intake groupbe Private 'For Sale' Classifieds 1 11-06-2003 11:08 AM
Cobb Tuning Cold Air Intake for 00-04 2.5RS bolohuu Private 'For Sale' Classifieds 1 09-27-2003 12:50 PM
COBB / APS Cold Air Intake tokigiracing Car Part Reviews 10 08-01-2002 12:18 AM
2000 Cobb Tuning Cold Air Intake Review Swivel1000 Normally Aspirated Powertrain 7 02-13-2001 10:17 AM
