Old 04-23-2005, 04:25 AM   #1
e-type
Member#: 85338
1995 Legacy
Default water goggling noise on engine startup
Hi
I have had a good read through other threads and can not see any other similar problems.
When I first start the engine of my 95 legacyGT say after a night of sitting I hear a goggling noise as if it is cooling water or the air con stuff, I guess like an air lock in the system somewhere, can anybody suggest what it is and how to over come the problem,
Thanks
e-type is offline   Reply With Quote
Old 04-23-2005, 10:33 AM   #2
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
I had that, too. It turned out to be a water bubble in the system.
Have you checked your coolant level?
IronMonkeyL255 is offline   Reply With Quote
Old 04-23-2005, 05:52 PM   #3
e-type
Member#: 85338
1995 Legacy
The noise appeared after having a full service completed which included replacing the cooling water, I actually think that you are right, do you know what was done to fix it
Thanks
Old 04-23-2005, 09:12 PM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
park the car on a hill w/ the front end in the air
start it up and while its still cold pop the cap
then fill it back up
alex
Old 04-24-2005, 03:07 AM   #5
e-type
Member#: 85338
1995 Legacy
Ok, sounds simple enough. I'll give it ago.
Thanks
Old 04-25-2005, 09:11 AM   #6
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
With the car parked and engine off, open the fill cap and sqeeze the main coolant line that comes off the radiator. This will "burp" the system.
legacy92ej22t is offline   Reply With Quote
Old 04-25-2005, 09:35 AM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
no offense man but its gonna require a LOT of burping if that air is in the heater core
hed be better off doing it my way
Old 04-26-2005, 03:01 AM   #8
e-type
Member#: 85338
1995 Legacy
I tried the incline option and I think I got some air locks out although I did take care, (slight power just in case anti freeze made a mess) I'll give it another go on a hill this weekend.
The comment that it may be in the heater coil sounds like my problem as the noise actually comes from behind the heater control's.
Do you slightly rev the engine while the cap is off ?
The burb option, maybe worth trying it in conjuntion with the hill option?.
Thanks
Old 04-27-2005, 03:29 PM   #9
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Burping while facing uphill with the engine running. While the engine is cold, so the fans won't start, and the thermostat is not open.
How would this get air bubbles out, let alone out of the heater core? Water and air both want to follow the path of least resistance, and the thermostat being closed the only moving anywhere is going to be in the top of radiator out the fill.
cjfike is offline   Reply With Quote
Old 04-27-2005, 03:29 PM   #10
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
it is a nice set of steps though.
Old 04-28-2005, 01:38 AM   #11
e-type
Member#: 85338
1995 Legacy
Cjfike, bearing mind what you have said I guess you support the uphill option without burping?
Old 04-28-2005, 08:56 AM   #12
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Yes and no. Stop the car facing uphill, and shut off the engine and let it cool down until you can grab the hose and hold on to it for a few seconds. With the thermostat hopefully still open, do the burping thing and the bubbles should move into the radiator. They would get trapped in the highest point and then once the fill is open you should start the engine top it off and have all the bubbles out of the system.
One thing to remember: unless you buy distilled water to fill the radiator with, water from any running source is going to have AIR in it. Once fresh water goes through one heating and cooling cycle, all that air is now going to be in your engine block looking for the way out (in all the wrong places).
Old 04-29-2005, 05:29 PM   #13
e-type
Member#: 85338
1995 Legacy
I'll give it ago
Thanks
Loud clacking noise on cold engine startup with video deepsouthwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 04-10-2009 08:36 PM
Noise on cold startup on 07. Anyone else have this issue? pinkertonpunk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 02-11-2008 07:46 PM
Turbo clanking noise on cold startup? enphorcerWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-12-2002 11:17 PM
('93-'01) Weird water pouring noise at startup! 97 Impreza Outback Sport itsmywifescar Impreza Forum 4 10-24-2002 02:54 AM
Engine tapping noise upon cold startup Racerx5410 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 04-12-2002 10:29 AM
