Old 04-23-2005, 10:15 AM   #1
txkellers
Member#: 62235
Default Cobb Stage 2 HWG???
I have heard of people who are having trouble reaching target boost after installing a TBE and Cobb Stage 2/93. Some have advised to load Stage 2 93HWG as the real time map. What is HWG, and how is it different from the standard stg 2/93 v1.03?
txkellers is offline   Reply With Quote
Old 04-23-2005, 03:39 PM   #2
aschen
Member#: 30733
2007 tiny car
striped
did this to my car. I was only hitting about .9mpa in 3rd and .105 from there up. I changed to the hwg map and now I am at .11 in 3rd and .12 on. More importantly the boost comes on faster. I am not sure why some cars need this map but mine has a TXS cat and the oem axel back. I think slightly more free exaust may be needed for the reg map.
aschen is offline   Reply With Quote
Old 04-23-2005, 05:04 PM   #3
txkellers
Member#: 62235
I'll give that a shot. I have the Cobb DP with stock STI axle back. Maybe that's the difference????
Old 04-23-2005, 05:47 PM   #4
Skeete
Member#: 52569
2004 STi
i was hitting too much boost with the full cobb tbe, 19psi, so i switched to the lwg version and now it's closer to the target boost
Skeete is offline   Reply With Quote
Old 04-23-2005, 06:07 PM   #5
rustyzipper
Member#: 79175
2004 FXT
Red
high wastegate. keeps the wastegate closed slightly longer
rustyzipper is offline   Reply With Quote
Old 04-24-2005, 12:00 PM   #6
subiguy
Member#: 78389
06 Spec-b
I've had the same low boost problem with my 04 sti. 16psi max with stg 2/93 map. so I loaded the hwg base map yesterday-still waiting for ecm to learn but I already noticed higher boost. I'm running the factory boost gauge so it's hard to get precise boost reading in psi. I'll be out running it today, if I can get a passenger to read the live boost off the AP then I'll post my boost levels. I only hope it's not too high...
04 sti
godspeed dp catless-greddy sp2 cat back
subiguy is offline   Reply With Quote
Old 04-24-2005, 05:16 PM   #7
WolfInSheepsCLothing
Member#: 61197
2004 WRX
vf39 + goodies...
when i reflashed the car, within a handful of 2nd and 3rd gear runs, i was hitting boost of upper 14's and lower 15's psi with the stage II hwy 91 oct. i live in an area with lots of hills, i'm sure that helped my advanced multiplier hit 16 pretty fast.
but the CEL code P0139 kept showing up after a week or two, i'd reflash it with the base map, but it would come on soon after. that code is on the list of "CEL Codes Defeated [WHEN USING AS BASE MAP]" as stated on cobb's website. but i have no idea why it came on so often. i'm using the stage II 91 oct map, and things are fine, but i miss that more aggressive map. maybe its just the CA gas thats messing things up
WolfInSheepsCLothing is offline   Reply With Quote
Difference between Stage 2 and Stage 2 HWG KDX AccessPort 8 08-11-2009 03:34 AM
Cobb Stage II HWG dyno vs. PDXTuning Stage II dyno WRX-Traterrestrial Proven Power Bragging 29 01-24-2006 04:19 AM
Anyone ran 1/4 mile with Cobb stage 2 and stage 2 HWG map? txl146 Engine Management & Tuning 2 05-15-2005 09:08 AM
water injection and cobb stage 2 HWG map feels good !! phamster Water/Methanol Injection, Nitrous & Intercooler Cooling 11 04-23-2005 04:01 PM
Cobb stage 2 HWG map WRXVII Engine Management & Tuning 1 08-25-2004 08:53 AM
