Old 04-23-2005, 11:59 AM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default where can I get a Analog to digital vechical speed sensor converter?
I just had my friend adam wire up my digital gauge cluster from an RS my car is a 94 L with a 94 WRX trans. he told me that he's seen an converter that you plug up to the analog cable and it'll convert the signal to digital for the RS mph to work. soo right now my car is running on limp mode and no mph soo help a guy out do u know where I could get one?
DAn
scobaru is offline   Reply With Quote
Old 04-24-2005, 03:36 PM   #2
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
bump anyone?
Old 04-24-2005, 04:21 PM   #3
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Why not wire in a speed sensor from the RS and go totally away from the cable setup? You might have issues anyways with that box your talking about. On the cars with speedo cables, the computer gets it's speed sensor signal from the gauge itself (The speed sensor is part of the Speedometer where the cable hooks into the cluster). I think you would have better luck if you got the speed sensor and the wiring from an any legacy 1995 or newer, or any impreza 1998 or newer. Just make sure the sensor and wiring come from the same car. It shouldn't be that hard to wire in.
wrx_driver_2002 is offline   Reply With Quote
Old 04-24-2005, 09:38 PM   #4
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
already tried it it screws in but thats all it'll do. I have an 01 parts car and I used that speed sensor but I screwed it in and wired it up and it does nothing
Where do I get the pipe to eliminate the first cat converter with the 02 in it?? RyanA Normally Aspirated Powertrain 8 10-05-2004 03:52 PM
Where can I get a place to host a few pics… 128d Mid West Subaru Owners Club Forum -- MWSOC 14 03-09-2004 01:04 AM
where can i get a used control arm + knuckle + ABS sensor aznfoos Canada Region Forum 2 11-08-2003 01:03 PM
Where can I get bigger brakes to sqeeze in the 16 OEM rims ??? rolln j Brakes, Steering & Suspension 12 06-22-2001 05:34 AM
where can i get gold bulbs to put in my fogs... shukes24 Interior & Exterior Modification 7 11-09-2000 12:40 AM
