Old 04-23-2005, 12:06 PM   #1
CaptainMorgan
Member#: 24660
2005 OBXT
Default Tuner, Wideband, and UTEC
I was curious if anyone knew how the Tuner from Turbo XS interfaces with the UTEC so that it logs all as one? I use a Lambda meter from ETAS at work and was wondering if this could be hooked up to the UTEC? Here are some quick specs:
Measuring ranges
Lambda
0.7 to 32.767
O2
0 to 24.41%
Air/Fuel ratio
10.29 to 327.67
Internal resistance of g-sensor
0.0 to 1,000.0
Transient time measuring system
2 ms transient time
Outputs
Analog output
0 V to 8.2 V (parameter setting)
Short-circuit proof and extraneous-voltage protected up to 40 V
Output resistance
2 kOhm
Serial interface
V24 (RS232), 38,400 Baud, cascadable with other devices
CaptainMorgan is online now   Reply With Quote
Old 04-23-2005, 12:42 PM   #2
StiDreams
Member#: 26315
07 Outback
Silver/Silver
It won’t work. That’s because the tuner is really the aggregation point for the log. The tuner controller is more like an aggregation point for both UTEC and WB data. The UTEC sends information to the tuner and not the other way around. The tuner then adds its WB data and sends it out to the computer.
In order to get another WB tool to log with the UTEC you need to log both (with RPM) and use the RPM data to merge the two logs. Some people here have done that here with the LM-1 and one other WB with a self written custom application.
StiDreams is online now   Reply With Quote
Old 04-23-2005, 08:41 PM   #3
MMBOOST
Member#: 24140
02 Impreza WRX
http://www.logmapper.com
Those custom apps are log mergers? Or do they do it in real time?
jason
MMBOOST is offline   Reply With Quote
Old 04-23-2005, 10:16 PM   #4
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I believe they were log mergers but I'm not 100% certain. To be honest I did not follow the threads closely as I ended up buying a Tuner.
TXS Tuner Wideband and Romraider logging NITROS Open Source Reflashes 6 04-04-2012 11:56 AM
Utec, Tuner Pro and NEW Bosch wideband sensor antonio_sti Engine/Power/Exhaust 0 09-09-2009 12:53 PM
FS in NY: tuner xs pro wideband and greddy bov STi in ur face Tri-State Area Private Classifieds 1 09-21-2006 05:06 PM
Pro-tuner and Utec tuning party version 2.0 mpower22 Mid Atlantic Impreza Club -- MAIC 43 06-27-2005 11:42 AM
TurboXS Tuner and UTECs in stock Prestige Motorsports Engine/Power/Exhaust 7 08-30-2004 09:18 AM
Message Board Statistics All times are GMT -4. The time now is 10:48 AM.
