Old 04-23-2005, 01:07 PM   #1
Jsunn
Member#: 15467
2002 Impreza WRX
Platinum Silver
Question Accessport and reliability...
I am going to be purchasing the Cobb AP SGT2 very soon and I just wanted to see what the verdict was on the long term reliability of the automobile.
My Mods include...
Gutted Airbox
SAMCO MAF Hose
K&N AF
SAMCO I/C Hoses
STi Uppipe
Bosla DP
Prodrive muffler
My car is an '02 and has 58+ Kmiles on it and the warranty will be gone soon, (probably gone already with my mods), but this car will need to last me a little longer.
Thanks for your input.
-Jason
Jsunn is offline   Reply With Quote
Old 04-23-2005, 05:05 PM   #2
rustyzipper
Member#: 79175
2002 wrx
careful with the aftermarket MAF hoses, may be a problem with turbulence and the AP doesnt like that , could be a prob, or not at all , car to car is different. but the hack + the hoses = different intake for the ecu and AP , could be risky.
rustyzipper is offline   Reply With Quote
Old 04-23-2005, 05:40 PM   #3
BIG GUN
Member#: 49825
2002 WRX WAGON
SILVER
I have silicone I/C hoses, and Hyperflow TMIC, and Trey said that was not a problem. I would be concerned about the chopped intake. That is best left alone.
BIG GUN is offline   Reply With Quote
Old 04-23-2005, 07:30 PM   #4
Jsunn
Member#: 15467
2002 Impreza WRX
Platinum Silver
Thanks I will keep an eye on that. I just ordered it this afternoon. I have the stock MAF hose if there are any problems. I just took out the silencer in the fender. The airbox itself is still unmodified.
I can't wait!!
-Jason
Old 04-25-2005, 08:52 AM   #5
Jsunn
Member#: 15467
2002 Impreza WRX
Platinum Silver
Bump....
No one has opinions on car reliability with AP?
-Jason
Old 04-25-2005, 09:27 AM   #6
WRX_2NR
Member#: 66763
04 WRX
1-YR 3-Months no problems
Hopefully that helps
WRX_2NR is offline   Reply With Quote
Old 04-25-2005, 09:54 AM   #7
rexorama
Member#: 25912
02 PSM Wagon
02 WRB Sedan
I wouldn't use stage 2 mapping with the Bosal downpipe and prodrive muffler. Their maps were created with a 3" turboback system, you still have a stock cat and 2.5" piping in place. You should use a 3" turboback setup.
I had the stage 2 AccessECU(pre AP) in my 02 sedan for 2 years, that ECU now lives in my 02 wagon and has been in that for 3 months, no issues. I've been running AP stage 2 on my STI for a month now, no issues with that either.
rexorama is offline   Reply With Quote
Old 04-25-2005, 10:07 AM   #8
Jsunn
Member#: 15467
2002 Impreza WRX
Platinum Silver
Thanks for the input. I am going to call Cobb and see what they say.
-Jason
Old 04-25-2005, 10:34 AM   #9
subieworx
Member#: 47769
Cobb specifically says that all that is needed to be stage 2 compliant is a DP with no cat. I ran stage 2 on my wrx with only a 2.5" shorty DP for quite some time with no problems. Performance was better once I finished off the exhaust, but there are not problems with using stage 2 like that.
subieworx is offline   Reply With Quote
Old 04-25-2005, 12:35 PM   #10
Jsunn
Member#: 15467
2002 Impreza WRX
Platinum Silver
Sweet!! My AP ships this week!!
I'll let you know.
-Jsunn
Old 04-25-2005, 02:59 PM   #11
dcwrx2
Member#: 69005
'04 4EAT Wgn
Originally Posted by subieworx
Cobb specifically says that all that is needed to be stage 2 compliant is a DP with no cat...
It should be fine for DP with high-flow cat to replace the 3rd cat (while deleting 2nd cat). Otherwise Cobb's catted DP is only good for Stg1 maps
dcwrx2 is offline   Reply With Quote
Old 04-25-2005, 03:43 PM   #12
Aaron_S
Member#: 82285
02 WRX wagon
Make sure you reflash with the most current base map. My AP shipped with V121 map and the most current is 122.
also, read the instructions...you'd be amazed at how many ppl screw things up with the AP cuz they were too lazy to read the directions.
Have fun and good luck on your reflash...its a scary 15 mintues =)
Aaron_S is offline   Reply With Quote
Old 04-25-2005, 06:39 PM   #13
Paulie V
Member#: 10260
2002 WRX Sedan
PSM- Cobb Stage 2- again!
Very true! I was going over everything twice, making sure nothing was on that would run off the battery, making sure that cable was firmly planted in the diagnostic port... But I'm feeling MUCH better now!
Paulie V is offline   Reply With Quote
Old 04-25-2005, 09:28 PM   #14
rexorama
Member#: 25912
02 PSM Wagon
02 WRB Sedan
Understood.
I'll never understand why you would only want a 2.5" setup though.... 3" and as straight as possible allows for much quicker spoolup then 2.5" and a stock cat.
Long term Turboxs st1 chip and reliability and fuel mileage? Camperguy Factory 2.0L Turbo Powertrain 4 09-15-2002 08:28 PM
Resale Value and Reliability of Subarus npolytar Newbies & FAQs 6 10-17-2001 01:41 PM
Need a cheap and reliable source for JDM side markers.... zelet Interior & Exterior Modification 16 10-17-2001 09:09 AM
What stock internals need to be replaced to run 10 PSI safely and reliably? (EJ25) wrxman555 Normally Aspirated Powertrain 5 02-23-2001 12:23 AM
Subaru service and reliability? baco99 General Forum Archive 8 01-19-2001 05:01 PM
Message Board Statistics All times are GMT -4. The time now is 01:47 PM.
