Old 04-23-2005, 08:53 PM   #1
buzz313th
Member#: 37008
2005 WRX Sedan (STX)
Crystal Grey -TeamBrew-
Default Burning out the stock WRX EGT sensor
I am using Street Tuner, the LM1 and Delta Dash to log and tune my 05 WRX.
I like the idea of being able to log egts with the stock sensor and DD.
I have a Cobb TBE and Upipe w/ EGT bung.
I am burning out a Stock EGT sensor every month.
My egt's are not high.... to my understanding... the reason the stock egts sensor burns out with catless upipes, is because the sensor is seeing a quicker transistion from high egts to low egts since the cat isn't there to smooth the transitions out.
Does anyone have a genius solution on how to keep from burning out the stock egt sensor with catless aftermarket upipes.
Until I find a solution I will keep replacing the egt sensors.
I guess the last option I have is to install an egt gauge and try to calibrate the LM1 aux input with DD to be able to log egts...
Any help would be appreciated.
buzz313th is offline   Reply With Quote
Old 04-24-2005, 04:51 PM   #2
BIG GUN
Member#: 49825
2002 WRX WAGON
SILVER
Just do the 1/2 watt, 2.2k resistor mod, and be done with it. And you can plug the bung with an M12 x 1.25 bolt, w/ a lock washer.
The only reason the EGT probe is there, is to let you know if the up-pipe cat gets to hot.
BIG GUN is offline   Reply With Quote
Old 04-24-2005, 04:57 PM   #3
hondaeater69
Member#: 60324
You're not melting the actual probe are you? It doesn't make any sense that the sensor can't handle swings in EGT's. Whether the cat is there or not, the sensor sees dramatic swings in EGT's. The precat is mostly for startup emissions.
Maybe a short in your system?
Old 04-24-2005, 05:35 PM   #4
gmanwrx
Member#: 53871
95 s14 240sx
ruby red
i'm having the same problem with u-tec also...
gmanwrx is offline   Reply With Quote
Old 04-24-2005, 07:34 PM   #5
crazymikie
Member#: 56321
2008 Lexus IS-F
Jeff-
I'm curious about this. I plan on putting on a catless uppipe soon and want to keep my EGT gauge for logging purposes.
I can't see why not having a cat in there would burn up sensors.
Mike
crazymikie is offline   Reply With Quote
Old 04-24-2005, 07:42 PM   #6
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
The stock EGT is a thremistor type and is 100% junk.....and is only used to monitor the UP cat temp......it is NOT a thermocouple type probe
Old 04-24-2005, 08:46 PM   #7
BlackedOutRex
Member#: 36172
2002 WRX Sedan
Midnight Black
Same problem with HKS up-pipe. Could try a spacer to expose less of the probe, about a 1/4 inch or so. Not sure how it affects readings but my sensors would last 25 to 50% longer. Finally I said tah hell with it and pluged in a resistor.
BlackedOutRex is offline   Reply With Quote
Old 04-24-2005, 09:48 PM   #8
buzz313th
Member#: 37008
The stock sensor uses a filiment in the middle. Without a cat the sensor heats up and cools off faster. It's the quick cooling that kills the stock sensor. Since the cat isn't there to keep it the temp up.
No it is not melting...
There is no short in my system.
Almost everyone who gets rid of there pre cat, will kill the stock sensor. It happens real fast.
Like I said in my original post... I want to keep using that location and sensor so I can continue to log egts with DD.. Not only that, but the OL/CL system uses the egt sensor for some calculations in the 04/05 WRX.
I guess I will just keep buying sensors, or taking the sensor out when I'm not logging.
Old 04-25-2005, 08:54 AM   #9
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...source of this information....link??????
Old 04-25-2005, 09:47 AM   #10
rexorama
Member#: 25912
02 PSM Wagon
02 WRB Sedan
Your best bet is to plug the bung for the stock sensor and get the stuff needed to read EGT with the LM1. I thought it would be nice to read EGT just like you have, but I had the same problem.
rexorama is offline   Reply With Quote
Old 04-25-2005, 09:56 AM   #11
SooobieSnack
Member#: 44380
Also, from what I've been told, the sensor must go back into the uppipe at the same angle that it was in the stock pipe. Hot gas flow over the wrong part of the sensor will cause the it to fail. Just what I was told, no proof here.
SooobieSnack is offline   Reply With Quote
Old 04-25-2005, 01:15 PM   #12
buzz313th
Member#: 37008
Talked to Bill at ISpeed and he assumes that this is the problem. Plus the only difference in egt logs with the stock upipe (w/ cat) and the AM upipe without cat, is quicker changes in egts, lower egts, lower idle temps down to 689F which is lowest tem the sensor reports.
Old 04-25-2005, 01:16 PM   #13
buzz313th
Member#: 37008
Well I just bought 2 more sensors for 25 a piece. I will actually put the sensor in for logging and then remove it and plug it for autocross.
Old 04-25-2005, 01:18 PM   #14
buzz313th
Member#: 37008
I think you may be on to the cause of this problem. I have the cobb Incanel upipe and I think the angle is slightly different. I will try rotating this instalation 180 degrees and see if it lasts longer than the last one...
Old 04-25-2005, 09:21 PM   #15
rexorama
Member#: 25912
02 PSM Wagon
02 WRB Sedan
I burned mine out in a TXS Cast up pipe, I didn't look at the position close enough to see how far off it was, if any.
Old 04-25-2005, 11:01 PM   #16
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....you didn't answer the question....
Old 04-25-2005, 11:06 PM   #17
buzz313th
Member#: 37008
Repeat the question.
Old 04-26-2005, 10:58 AM   #18
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
where did you get this info
its also the first that i have heard about it
Old 04-26-2005, 12:28 PM   #19
buzz313th
Member#: 37008
Ohh.. sorry missed that...
With Street Tuner you can force the ECU to switch to Open loop once the egt's rise to a certain point... then set the Egt for the car to go back to CL... Here is what I am talkin about.
As you can see... When egt's hit 1640 the car will switch to OL no matter what.... below 1600 it will switch to CL... This is more or less a safety feature to allow the car to run OL (Rich mixtures) if the car is too hot durring CL... But I have a feeling this same feature can be used to force the car into OL sooner for specific tuning applications....
Old 04-26-2005, 05:30 PM   #20
BIG GUN
Member#: 49825
2002 WRX WAGON
SILVER
I would be in a panic about meltdown if I saw those temps!
Anything above 1500 or so is reason for concern.
Old 04-26-2005, 06:31 PM   #21
buzz313th
Member#: 37008
So would I.... beleive it or not the stock values are around 1900F
But my point of the screenshot was just to answer the question...
You could enter values such as 1200F and you could be open loop after 1200 F...
Old 08-12-2008, 10:44 PM   #22
Jus Blaze
Member#: 129428
2002 Wrx
Ok so I did this mod but Im not sure if I bought the right resistor. The item number from radio shack is 271-007 and the name of the product is " 2.2-kohm 1/8-watt carbon-film resistors". The reason why I think its the wrong ones is because after installation, I had hesiation in throttle response and at start up, my rpms barely jumped. I quickly took out the resistor and replaced it with the egt plug. I hope i didnt cause any damage. Can someone shed some light one which resistors im suppose to use?
Jus Blaze is offline   Reply With Quote
Old 08-13-2008, 05:15 PM   #23
Gethin
Member#: 2998
should be 1/2 watt and not 1/8 watt.
should not affect your car in that manner though.
worst that can happen short term is that the resistor might get hot and melt.
Get a 1/2 watt one instead and reset your ecu.
Gethin is offline   Reply With Quote
Old 08-13-2008, 10:41 PM   #24
eminehart
Member#: 11205
2009 WRX
Dom3-e85-ewg
The catless uppipe shouldn't have anything to do with the egt sensor's life.
JDM and other WRX's have no cat and neither do STI's.
eminehart is offline   Reply With Quote
Old 08-17-2008, 12:29 PM   #25
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
yeah but it does ...
either that or the acids on your fingers kill the TC
WTB: Stock 2002-2005 WRX EGT Sensor Computergeek24 Private 'Wanted' Classifieds 2 01-21-2008 11:45 PM
WTB: Stock front EGT sensor-broken pdippel Private 'Wanted' Classifieds 2 08-02-2005 10:42 PM
02 stock uppipe EGT sensor anthonyrb98 Private 'For Sale' Classifieds 0 04-17-2005 12:19 PM
What type of sensor is the stock WRX O2 sensor? Patrick Olsen Factory 2.0L Turbo Powertrain 7 08-06-2002 05:17 PM
Message Board Statistics All times are GMT -4. The time now is 12:57 AM.
