Old 04-23-2005, 09:00 PM   #1
buzz313th
Member#: 37008
2005 WRX Sedan (STX)
Crystal Grey -TeamBrew-
Default RPM Pulses with the LM1
What is the easiest way to get RPM info into the LM1 from the WRX?
What is the most accurate way to get RPM info into the LM1 from the WRX?
I have the LM1, the RPM converter and the inductive clamp...
buzz313th is offline   Reply With Quote
Old 04-23-2005, 09:07 PM   #2
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
You can't with a WRX - they have coil on plug. Best way to get RPM is to tap the wire on the ECU.
Geek Guy is offline   Reply With Quote
Old 04-23-2005, 09:40 PM   #3
buzz313th
Member#: 37008
Thanks...
Do I use the metal rings that come with the front Koni inserts? lotarg Newbies & FAQs 3 06-03-2010 03:09 PM
VSS Pulses and RPM Pulses bmw50021 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-22-2006 04:28 PM
LM1 users - did you have trouble with the serial interface? Gethin Engine Management & Tuning 0 02-18-2006 01:09 AM
Anyone run a 1/4mi with the JDM 5th and 6th in the 6MT?? plus coasting RPM? BigJ04STi Transmission (AT/MT) & Driveline 3 01-13-2005 01:26 PM
Ok what's with the rpm spike when foot's off the gas? Undepelo General Community 38 02-02-2004 10:26 AM
