Old 04-24-2005, 10:11 AM   #1
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
Default information about version 7 cluster shift light and outside temp
I put a version 7 gauge cluster in my swapped car and in the beginning the shift light would beep when I reached the correct RPM. I then figured out how to change the RPMs by fiddling with the knob on the left, but now it no longer beeps. I want it back, how do I do it?
Also I have an outside temp gauge that doesn't work, I seem to remember there was a tutorial somewhere to wire it up and make it work. Anyone remember?
Thanks
Capt Crunch is offline   Reply With Quote
Old 04-25-2005, 03:48 PM   #2
subimp6u08
Member#: 15440
2015 STi
for the outside temp gauge
search for ambient sensor...
i have v8 cluster, and my temp gauge doesn't work for some reason, after following the tutorial. maybe i have loose connection or something.
subimp6u08 is offline   Reply With Quote
Old 04-25-2005, 11:31 PM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
cnk is offline   Reply With Quote
Old 04-26-2005, 05:08 PM   #4
Capt Crunch
Member#: 10852
Originally Posted by cnk
thanks!
any idea on the shift light? It perplexes me because it was working. It only blinks now.
Old 04-26-2005, 06:44 PM   #5
Handsdown
Member#: 29355
did you try pushing it in? i thought the buzzer was selectable(push to turn on/off?)
Handsdown is offline   Reply With Quote
Old 04-27-2005, 12:07 AM   #6
smdandb2
Member#: 70656
Old Mazda3 Hatch
Shelby Lancer #623
I know on my V8 cluster after you adjust the shift light position, it then changes to where you can turn the beep on and off. I did not know the V7 cluster had a shift light...
As for the temp gauge, you have to wire up the sensor.
smdandb2 is offline   Reply With Quote
Old 04-27-2005, 08:46 AM   #7
prelude/2.5rs
Member#: 9355
2007 Infiniti FX35
2008 Mazda3 Hatch GT
What you do is turn the key to the on position and turn the knob to the left...IIRC. You then can set the RPM level and it will then ask beep or no beep(in it's own language)...I believe it will say on/off. Select "on" w/ the knob. You should be all set. Let us know how it works out.
Mike
prelude/2.5rs is offline   Reply With Quote
AR: WTT JDM STi Version 7 Cluster suby_will Interior/Dressup/Audio & Security 9 03-05-2008 02:38 PM
WTB JDM version 7 cluster roninrider_9 Private 'Wanted' Classifieds 0 02-16-2008 07:04 PM
2004 WRX Cluster. Has Shift Light and Buzzer Incorporated - $ 255 gedwrx Interior/Dressup/Audio & Security 13 03-15-2007 09:27 PM
Ver7 JDM STi Non-DCCD Cluster With Shift Light and Guage Bezel subydude Private 'For Sale' Classifieds 10 03-31-2006 11:57 PM
STI Version 7 Cluster StevieD Private 'For Sale' Classifieds 1 01-13-2004 07:22 AM
