Old 04-24-2005, 02:03 PM   #1
wrx02racer
Member#: 52864
2002 wrx
blue
Default txs tuner pro
Any suggestions on where to wire in the power for the tuner? any ideas would be appreciated
thx
wrx02racer is offline   Reply With Quote
Old 04-24-2005, 05:39 PM   #2
MMBOOST
Member#: 24140
02 Impreza WRX
http://www.logmapper.com
Depends on where you want to physically install it. The clock is always a good option.
jason
MMBOOST is offline   Reply With Quote
Old 04-25-2005, 01:53 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
I took the ignition wire from under the stock clock and connected it to a relay(to activate the relay when the car turns on). Then I got a new wire from the battery and attatched it to the power source for the relay, and put a 15 amp fuse in it. Next I took the the wire going from the relay to the tuner and put a fuse in it(I forget, 1 or two amp, it's in the tuner manual). Then I attached a long ground wire to the tuner ground and attatched the other end to the frame of my car near the ecu(under the passenger side door). If you have a lot of things to power, you could use that relay to power other relays instead of connecting it right to the tuner. If ya have any questions, just ask.
peace
TXS Tuner Pro installed pics needed! Crazykev Member's Car Gallery 4 12-31-2005 07:02 PM
Additional Knock Sensor Location - Aftermarket - TXS Tuner Pro crystalhelix Engine Management & Tuning 5 10-11-2005 06:51 PM
Wtt Avic N1 For Aps Tbe And Txs Tuner Pro wrx614 Private 'Wanted' Classifieds 5 07-19-2005 05:45 PM
FS: New TXS Tuner Pro Spin4 Private 'For Sale' Classifieds 5 07-01-2005 08:45 AM
TXS Tuner PRO. JDM STi v7 ECU Soon2Bgreat Private 'For Sale' Classifieds 26 12-21-2004 06:28 PM
