Old 04-24-2005, 09:37 PM   #1
Way2Slow
Member#: 61903
Question Boost Problem?
I'm not really sure what is going on but I have an '04 Sti that is stock except for a Utec and when running on the stock ECM I'm only getting about 11psi but when I'm on the base TXS stage1 map I'm getting 15.5-16psi, which is the amount I should be getting. So is there really a problem or should I not worry about it. Thanks
Way2Slow is offline   Reply With Quote
Broken Boost Gauge or Boost problems? undrgroundskat3r Newbies & FAQs 7 08-03-2009 01:02 AM
Boost Problem / Wastegate*solenoid* Problem?? WhiteRu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-23-2009 08:17 AM
GT35r problem/ boost problem builtgt35rsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 05-11-2009 10:27 PM
Boost problem...did i fry my stock boost controller brazymstrp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-30-2004 03:14 PM
Help with boost upgrade - high boost problem alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-06-2001 07:15 AM
