Old 04-24-2005, 10:21 PM   #1
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Lightbulb How many CC do you put for Modded wrx injectors?
Im running 750 right now. I left the other value(stock) at 420.
I am really curious what kind of values people are running with their modded injectors on the wrx. If you are running strait thru TGV's, please mention that as well.
I'd also like to know if you have to add/remove fuel in the 0% columns for smoother idle, especially cold idle startup.
Thanks,
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 04-24-2005, 11:41 PM   #2
DjRez4
Member#: 18155
1985 4runner
AWD Pirates, Unite!
If you have the injectors set properly, you shouldn't have to adjust 0% for proper fueling. I have mine temporarily set at 740, but I know for a fact that the setting is way too low. My LT and ST fuel trims are maxed lean to compensate for the improper injector sizing and the CEL is on. This should all get sorted out on Tuesday at the dyno.
DjRez4 is offline   Reply With Quote
Old 04-25-2005, 12:33 AM   #3
Bolster
Member#: 22290
2002 WRB WRX Wagon
I had mine at 760 and it was still pretty rich. Starting at 740 doesn't hurt, but I think you'll find yourself working up to a higher setting. They flow a ton.
Bolster is offline   Reply With Quote
Old 04-25-2005, 05:05 AM   #4
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Perhaps mine dont flow much more than 750 because when i reset the ecu with the engine warmed up already(and my 0% column at all 0), it initally runs lean, like 18:1 until the st and lt compensate and add fuel. There was a thread somewhere that had people saying that they had to add fuel in the low-rpm areas of the 0% column for some reason for it to idle correctly. I have 2.5 in my 0% up until around 2k, otherwise it will idle really lean and cough and almost stall from not having enough fuel to combust.
I would like to get ahold of a deltadash for a few days and see what my trims are. I wish somebody in jax had one i could borrow for a week or so.
i've run the injectors as high as 800 in the past but it was harder to tune for some reason. With them at 750, my map from 10%-100% is pretty close to zero, so i think that is a good spot for me to be at.
Jeff
Old 04-25-2005, 10:02 AM   #5
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
You should always run RICH on startup (like 12:1) and then your ST should fall in the -10 to -20 range. This is because the pump initially is run at 100% IDC. Once it cycles down to 33%, you'll notice that as the car warms up your ST trim gets closer and closer to zero.
Basically you know you're on the right track when the car is +- 5% ST with 0% LT, it idle, and a cooling fan cycle still keeps you in that +-5% ST.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 04-25-2005, 10:09 AM   #6
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
I'm at 820cc right now; have been all winter; and I still have to put up to -2.5 in some columns of my fuel map. I've increased my stock fuel pressure by about 5psi, though.
Zackbo is offline   Reply With Quote
Old 04-28-2005, 06:11 PM   #7
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
I am seeing the exact same thing. Mine is set for 750, but I had to up the low idle to about +3 to +4. Anything lower and it starts to lean out and can't compensate.
TyranosaurusWRX is offline   Reply With Quote
Old 04-28-2005, 06:36 PM   #8
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
I'm running a value of 740 even though I had them flow tested at 43.5psi to 835-840cc. I originally started with a value around 5 to 6 for the 0 load column, but once the motor warmed up completely it was pig rich and I had maxxed out the st fuel trim trying to pull fuel. I've narrowed down to a value of 2 and it keeps the ST fuel trim -5 and the LT at 0 once it's at normal operating temperature.
jetskizero is offline   Reply With Quote
Old 04-29-2005, 08:46 AM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i've heard it said that the modded stockers flow less fuel at low DCs than the proportionality would have you believe... thus the need to bump maf a bit down low.
Old 04-29-2005, 10:55 AM   #10
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Im running them at 800cc right now and coldstarts are rough. It will wander and go as lean as 20:1 several times until it finally warms up. I will probably end up running a few points in the 0% near idle rpms.
Jeff
How many miles do you put on your suby per year? Gel Mibson General Community 87 02-18-2010 02:58 PM
how many miles do you have on your wrx racekar Service & Maintenance 18 03-31-2006 05:43 PM
How many cc do USDM 04 STI injectors flow? STI spec D Newbies & FAQs 5 02-02-2006 12:52 PM
how many KM do you get on Accessport's economy map for 02 wrx sadd16 Engine Management & Tuning 0 09-22-2005 02:44 PM
WRX durability? how many miles have you put on your wagon or sedan 5M? ufoguy Newbies & FAQs 14 11-10-2003 04:33 PM
