04-24-2005, 11:59 PM | #1 |
Member#: 85787
Vehicle:2005 Impreza WRX Crystal Grey (Sold) |
HID install Trouble. Please Help!
Ok , This is the story. I am trying to install an aftermarket HID kit on my 05 WRX. I am connecting the the red and black wires from the ballast harness to the red and black wires of the stock bulb Harness. When i try to turn it on the bulb does not fire up. So then i decide to check if it will fire up if hook it up directly to the car battery. Presto , they fire up perfectly. Can Anyone please tell me why i am experiencing this trouble?! I have previously installed 2 hid kits on two different other cars with no hassle. Does the Imprezza have something weird concerning how hid kits can be wired that i need to know?
04-25-2005, 12:30 AM | #2 |
Member#: 29355
NWIC
impreza, one z.
have you looked in the HID faq? subarus use a switched ground... does that have anything to do with it? |
04-25-2005, 07:30 AM | #3 |
Member#: 85787
I searched and it looks like i maybe found the solution. It seems that i have to hook up the wires red and black from the ballast in reverse to the stock wiring. Can someone please verify that for me.
04-25-2005, 07:55 AM | #4 |
Member#: 49297
NESIC
Vehicle:17 WRX Limited |
Where did you get the kit from? When i did mine, it was self explanitory. I wouldn't hook anything up in reverse, thats asking for trouble. This doesn't sound like a very PnP kit, and you should probably contact whoever sold it to you.
04-25-2005, 08:03 AM | #5 | |
Member#: 85787
04-25-2005, 01:34 PM | #6 | |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! White |
04-25-2005, 01:57 PM | #7 |
Member#: 85787
i got it from proxenon
04-26-2005, 08:06 AM | #8 |
Member#: 85787
ok , solved the problem with a test light . Turns out the the factory H1 bulb harness is color coded in reverse. Black is Positive and Red is negative. Why did subaru do this is beyond me
04-26-2005, 08:41 AM | #9 |
Member#: 10309
NWIC
Yes, for OEM wire colors you really need to look up their function in a wiring diagram; it's not like aftermarket radio harnesses where standard colors are almost always used.
07-23-2005, 12:27 PM | #10 |
Member#: 17069
TXIC
Vehicle:2013 SLow White |
i did my backward cuz the the white line is actually the ground, Khid brand
and 05 wrx |
HID installation problem, PLEASE HELP | jcramer425 | Electrical & Lighting | 5 | 10-19-2007 07:11 PM |
Brake Pad install trouble PLEASE HELP | Fitz12444 | Brakes, Steering & Suspension | 14 | 08-12-2007 11:31 PM |
car trouble, please help | sregger | Normally Aspirated Powertrain | 7 | 08-08-2005 08:41 PM |
Radio Trouble, PLEASE HELP | Dan8304 | Car Audio, Video & Security | 1 | 04-17-2005 10:28 PM |
Bulb trouble..PLEASE HELP | 2000LegacySti | Electrical & Lighting | 2 | 12-22-2003 10:38 AM |
