Old 04-25-2005, 12:00 AM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default Should I get engine management if the motor is running fine?
I am running 7psi starting at 1500 rpm, climbs to about 9 at 6000 rpm. This is produced via a supercharger on a NA 2.2 block and ECU. If I run 94-96 ocatane fuel (made by mixing some tolulene into premium) I don't suffer knock. I have dynoed at 152 whp and this was with a clogged fuel sock and one sparkplug wire not connected properly. The stock NA 2.2 got about 90-100 whp. I get decent milage when sane (19-22), 12-16 when not.
So is there any reason to upgrade to anything if the wagon runs fine? Would I benefit by a huge margin or just slightly?
Thanks.
Old 04-25-2005, 10:11 AM   #2
rexorama
Member#: 25912
03 MBP Sedan
02 PSM Wagon
The best thing to do would be to data log somehow to see what your motor is doing exactly. EM and the ability to tune can do more then just add power by fine tuning, it can also smooth out the power band (if it need to be). There could be as little as 10-15 WHP there or as much as 30. On top of this, EM will give you the ability to possibly add more boost. You may also increase milage with fine tuning. Your motor is running without knock right now, but that doesn't mean it's running well.
Sounds like a nice setup you have.
rexorama is offline   Reply With Quote
Old 04-25-2005, 07:09 PM   #3
awilson529
RIP
Member#: 38867
11 Mazda
Are you atleast running an EGT? If so, what's it read? If not, how do you know it's running fine?
awilson529 is offline   Reply With Quote
Old 04-25-2005, 07:52 PM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I have a Greddy EGT guage. Only the probe is longer than the diameter of my exhaust!
I am assuming it is running fine cause nothing has melted or broken yet in the 6 months I have been running it at the 7 psi.
Old 04-26-2005, 11:04 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
a few runs with an EGT probe or a wide band would provide you a much better answer
did they put the wide band on when you made your dyno run?
Old 04-26-2005, 11:07 AM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
no. cause the dyno run was "free" and I didnt want to ask to much.
Old 04-26-2005, 05:05 PM   #7
bboy
Member#: 56468
04 Improved STI
Dirty White
Agree with the others, you don't know that you are "running fine". You need data, then I'll bet you'll need EM.
can you tell if the motor is going by a datalog from romraider? DNA Motoring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-30-2010 10:41 PM
Engine management for hybrid motor djelly84 Built Motor Discussion 4 11-18-2009 05:12 PM
When should I get Engine Management? kochj23 Engine Management & Tuning 8 04-06-2004 03:59 PM
My check engine light is on but car is running fine. Ripper Normally Aspirated Powertrain 27 09-24-2001 11:59 AM
