Old 04-25-2005, 10:16 AM   #1
staticfritz
Member#: 66934
2004 JBP FXT
2002 cammed OBS - RIP
Default obdII scanner suggestions?
can any of you suggest an odb2 scanner/code reader/status monitor?
i was looking at the actron cp9135, but am not sure t'll do everythign i need.
i'd like to be able to monitor the a/f and o2 values etc.
would i be better off with an ebay obd2->serial converter and using a pc?
i'd rather not spend more than $100.
lemme know what you all think/have experienced. thanks!
staticfritz is offline   Reply With Quote
Old 04-25-2005, 11:01 AM   #2
rexorama
Member#: 25912
03 MBP Sedan
02 PSM Wagon
Perhaps this is up your ally
http://www.autoenginuity.com/
They sell them on EBAY for a bit less then on their website. I have heard good things about them and was going to try it out myself but it would be pointless for me since Access Tuner will log all of that and that is my planned route.
rexorama is offline   Reply With Quote
Old 04-25-2005, 12:17 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
standard obd-2 readers are almost completetly uesless at 1-2 samples/sec
look at delta dash and there is also a ce software that is in the vendor software somthing with subaru select protocol up to 8 samples/sec
at under a $100 all you get is a blinky light toy that can read and clear codes
Old 04-25-2005, 08:04 PM   #4
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
Go to openecu.org and look at the project hardware. It will run many ODB software packages, and do SSM. Still a long way to go on it, but it is picking up fast.
Or get the www.digimoto.com ELM based tool. Both are under $100. The ELM tool is more mature, but slow and limited. The project tool is early beta, but more potential.
bofh is offline   Reply With Quote
Old 04-26-2005, 01:57 PM   #5
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
You can try this one. I picked it up for about $80 and works like any other code scanner. It's an OBDII->serial and the software runs on the PC. I don't know if you can read AFR values, but you can get MOST of the generic OBDII functions from it. Most importantly, for UTEC users, you can see ST/LT fuel trims, intake temp, Open/closed loop fueling mode, and can pull and reset CEL codes. You can also look at your freeze frame data when you do get a CEL. Nothing real fancy, but it works and is cheap...even cheaper if you want to build it yourself.
Try this:
http://obddiagnostics.com/order.html
BTW, it supports all 3 OBDII formats (PWM, VPW, ISO-9141, ISO 14230) which means that there is extra OBDII support for Ford and GM cars, and it reads all Japan cars. I'm not sure about british cars as there are some that are different spec.
-jason
jmussetter is offline   Reply With Quote
Old 04-26-2005, 02:10 PM   #6
staticfritz
Member#: 66934
2004 JBP FXT
cool beans
Old 04-26-2005, 09:12 PM   #7
epicurux
Member#: 3634
Default Has anyone tried this?
http://laplogger.com/
at $60, it seems like a good deal if you don't care about the GM & Ford compliance.
epicurux is offline   Reply With Quote
San Diego/North county OBDII scanner WRX216 Southern California Impreza Club Forum -- SCIC 0 09-23-2001 02:41 PM
No boost but no CEL?? ideas? OBDii scanner help? iceweazel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-21-2001 05:18 PM
('93-'01) OBDII scanner? gossamer_monster Impreza Forum 3 08-14-2001 11:46 PM
Anyone with an OBDII scanner? WRXThis Rocky Mountains Impreza Club Forum -- RMIC 2 08-01-2001 12:36 PM
neone have an OBDII scanner? m750 New England Impreza Club Forum -- NESIC 10 05-19-2001 07:05 PM
