Old 07-26-2001, 11:47 PM   #1
SubaFastR
Member#: 5786
Arrow Tec 2 install difficulty?
How hard is it to install the Tec 2? What is involved?
Kevin
SubaFastR is offline   Reply With Quote
Old 07-27-2001, 12:08 AM   #2
MikeyG
Guest
Member#:
Well here is the FAQ incae you didn't find out where it was yet.
Now I haven't installed a TEC II system but it seems that you will need to splice into the factory system in a few places and you will also get a whole bunch of new sensors to replace the factory ones. ( I hear the O2 sensor is rather hard to get at as a heatshield gets in that way.)
Actually the install isn't the hard part at all, it is the tuning that is. So you have a great bunch of people over at www.vishnuperformance.com to help with that.
MikeyG
Old 07-27-2001, 12:13 AM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Kevin, message Kartboy. He can help you install and tune it.... He told me that a person should be able to do it in less than a day
kastle is offline   Reply With Quote
Old 07-27-2001, 11:28 AM   #4
RyanC
Member#: 2634
1988 5000 CS Quattro
Tornado Red
If you aren't a mechanical moron it's not that hard. Of course, having proper tools is key to any successful endeavour but if you do, Shivs instructions are pretty good and you can figure it out.
RyanC is online now   Reply With Quote
Old 07-27-2001, 12:52 PM   #5
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Yes, proper tools are essential. and if you've got a MY00 or 01(I think) you'll need some O-rings for the injectors. It took me about a week to get it all in, but I was only working in the evenings and I was making sure that my car would still run properly the whole time. I took it in stages as it is my only car. I was w/o car only one day, and that was because I didn't have all the o-rings for the injectors. 2 tools you'll need that I didn't have were a 22mm socket(an impact socket would probably work best, as they seem to be the tightest fitting) for the crank pully. And this one is a PAIN IN THE A$$, so good luck. You'll also need a 22mm open end wrench for the O2 sensor. you can't get a socket on it because of the wires. It has to be the right length too. Too short and you'll never get the sensor loose, but too long and you'll never get clearance to put get it on the sensor. Other than that, it was surprisingly simple.
mrbell is offline   Reply With Quote
Old 07-27-2001, 04:41 PM   #6
DaveK
Member#: 2338
1988 323 GTX
black
I'm planning on doing it a week from sunday so I'll report back...I've been studying the instruction manual so hopefully there won't be any big surprises.
DaveK is offline   Reply With Quote
Old 07-27-2001, 04:59 PM   #7
wop
Member#: 1931
2000 00 impreza 2.2l
wagon
Default Re: Tec 2 install difficulty?
Kevin
I thought you were going wolf 3D? are you changing up on me now?
-wop
wop is offline   Reply With Quote
Old 07-27-2001, 07:14 PM   #8
SubaFastR
Member#: 5786
All depends on what happens with Dan's car.
Kevin
Old 07-27-2001, 07:31 PM   #9
wop
Member#: 1931
wagon
Kevin
jesus christ... does this mean I have to get a motec system?
-wop
Old 07-27-2001, 07:35 PM   #10
SubaFastR
Member#: 5786
What, are you trying to one up me? It's futile, don't forget the 180 HP of nitrous available to me.
kev
Old 07-27-2001, 07:45 PM   #11
wop
Member#: 1931
wagon
kev
who says I didn't get NOS and pistons? my philosophy... it's not about money it is about priorities... and right now the pockets are deep and the car is the priority... one call to our friends at U.P.R.D. and things could get very interesting...
kev
NO! I just like giving you a hard time bro. I was just razzing ya !!!
-wop
p.s. nothing is "futile" .
Old 07-27-2001, 09:04 PM   #12
SubaFastR
Member#: 5786
So, has anyone's motor detinated (or just mechanically failed) while using a properly tuned Tec 2? Shiv, how far have you taken your stock internals?
Kevin
Old 07-27-2001, 09:11 PM   #13
Member#: 67
1999 Outlasting
the competition.
well i'm at 10 pounds with a screamin fast car
i have no problems with dett. but you have to tune it that way.
if you remember a while back shiv went to try adn blow the car up. well he kept trying but the injectors maxed out and that was all she wrote. that tells me ALOT when you can hold the thing WFO and it will just kind of peeter out and not BANG like others have done.
my2c
Old 07-27-2001, 09:26 PM   #14
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Detonation!!!!
Kevin
Try asking AdamRS in New York. His motor went kaboom over 16psi. He should be able to explain to you the details. His car is back together and sold though but still.
Kevin Thomas is offline   Reply With Quote
Old 07-27-2001, 09:37 PM   #15
SubaFastR
Member#: 5786
I don't think Adam was using the Tec 2 at the time
Old 07-27-2001, 11:06 PM   #16
shiv
Member#: 607
Correct. Adam was not running a TEC-II.
Shiv
shiv is offline   Reply With Quote
Old 07-28-2001, 05:37 PM   #17
shiv
Member#: 607
Kevin
I only know of one customer car that has mechanically failed with the use of a TEC-II. It was from running 10psi of boost with a T28 turbo and no intercooler. Charge temps approached 100 deg. C and the car detonated itself during a 5th gear top speed run. No amount of tuning can keep such a system together. Now, that same car safely runs another MY00 motor with an intercooled Minnam turbo kit at 10psi.
There was also one other failure a while back that was caused by running the car without oil (big oil leak) but that can't really be attributed to tuning, boost, hp, or anything else.
That's not to say that there haven't been more TEC-II'd cars that have failed, of course. Last year, I blew up a Miata on the dyno. It wasn't really a surprise as it was making 280rwhp at 14psi on 92 octane pump gas at the time. Figured the cost of another junkyard motor ($500) was worth the learning experience
Back to Subarus. Most of my customers run their cars with a significant safety margin. All run good gas. All have big fuel pumps. All run nice and fat under boost (with low EGTs). All operate with a good 2-3 degree of safety margin against detonation (or at least they tell me ). All the higher boosted folks use upgraded fuel rails. There are also a few protections that I integrate into the TEC-II baseline maps before sending them out. One is a fuel cut that activates in the case of an overboost/wastegate failure. Another is a pretty aggressive intake temp-induce ignition retard that provides additional safety in case of heatsoak. Another is extra conservative fuel and timing maps just above the boost at which the system is designed to operate at. Few other things as well. Most of which most of my customers may not even be aware of
But is that to say that my kits are idiot-proof? Nope. It just says that my customers aren't idiots
My kits are not designed for those who like to see the boost needle go up and up and up. It's designed for those with safety on their mind. And done correctly, it is possible to have both safety and performance. Until we get to the last, say 10% of a systems potential, they are not mutually exclusive.
On 92 octane pump gas, running 9psi of boost, my MY99 2.5RS turbo routinely makes 265-275 wheel hp (as measured on a 2wd Dynojet). On 96 octane, at 13psi of boost, it made 295 wheel hp before the injectors reached their absolute limits. Stock wheel hp, by comparison, is 120-130.
But most customer cars are conservatively tuned, at first, to run 7psi on pump gas. They make a solid 225-235 wheel hp as illustrated by the last East Coast tuning/dyno day. And they do so in a variety of conditions, ranging from day-to-day street us and all-out track days. As time goes by, the customers usually start creeping upward. But none, AFAIK, dare to go above 10psi. Simply not enough fuel injector (and we use 550cc/min injectors!) to support that kind of power safely. Following these guidelines have proven to be effective when it comes to making good power while keeping the motor in one piece. And with nearly 100 TEC-II users out there, even a 5% engine failure rate would suck.
In the end, safety comes first. Especially when dealing with other peoples' cars. That, of course, requires descretion from the customer as well as from me (from the advice I give.) Except Kartboy's, of course He's a nut and just wanted to go stupid fast!
There's really a lot to the engine mangement thing. And I try my best to make sure that all of my customers are on the safe and narrow. And I encourage them to ask as many questions as they can. And I try to answer them as accurately as possible. Because not knowing something is the easiest way to blow a motor. But after some time, they learn it all and only call me when they want stickers or to ask whether I not I shipped out their last order... doh!
Cheers,
shiv
vishnu performance systems
Old 07-28-2001, 10:20 PM   #18
RS'ted
Member#: 3234
Stickers !!! You've got stickers ??? I see where I rate......
Ken M
RS'ted is offline   Reply With Quote
WTB: TEC-2 or TEC-3 Boost4U Private 'Wanted' Classifieds 3 11-18-2003 10:10 AM
Good News for PossumLink, LinkPlus, Tec-2, and Tec-3 Owners! DataLogLab Engine Management & Tuning 18 04-24-2003 05:49 PM
cam/timing belt tensioner self installation difficulty? BamBooI Service & Maintenance 4 07-23-2002 01:37 PM
Primitive Lip (STI/OEM) installation difficulty level? RossWRX Interior & Exterior Modification 4 06-19-2002 02:24 AM
TEC-2 Installation Party mastervic27 North West Impreza Club Forum -- NWIC 0 04-20-2002 06:43 PM
