Old 04-25-2005, 07:09 PM   #1
AK'S REX
Member#: 12163
Default Spark plug tuning?-Big turbo
What plugs are you big turbo guys running on pump gas?
I'm running basically a [email protected]+ psi on 93 octane, 850 cc injector w/ dual feed fuel rail setup. The problem is that I've been completely fouling my plugs on the street under normal driving(under 1k miles), I'm rarely in the throttle. I'm running NGK BKR7E's gapped at .032, I've tried BKR6E's but I've got to pull too much timing for them to run right. I know it's a rather fat map as far as the fuel tune is concerned, but it's nothing ridiculous.
Just curious to know what you guys are running or have had luck with. Open to suggestions.
Thanks,
-Adam
AK'S REX is offline   Reply With Quote
Old 04-25-2005, 08:15 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Sounds like you need to get a tune if you are fouling them. Another idea is to try Beru Spark Plugs. Harley Guys use these and they are supposedly foul proof, even running submersed in gasoline.
Old 04-26-2005, 09:55 AM   #3
MMBOOST
Member#: 24140
02 Impreza WRX
http://www.logmapper.com
This is a WRX? That gap sounds a bit big.
MMBOOST is offline   Reply With Quote
Old 04-26-2005, 10:24 AM   #4
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
What does nothing ridiculous mean? You have a wideband right?
BKR7E should work just fine at 0.028.
mbiker97 is offline   Reply With Quote
Changing spark plugs on 05 turbo... tips anyone? baja_burrito Baja Forum 25 02-25-2010 10:42 AM
Confused about copper spark plugs... 2.5L turbo garretts77 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-04-2008 10:33 PM
Spark plugs for baja turbo swazz Baja Forum 16 09-03-2008 11:10 AM
Spark Plugs/Tuning Question Prodian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-13-2007 10:07 AM
Spark Plug upgrade for turbo J Colman General Forum Archive 2 12-07-2000 11:58 PM
