Old 04-25-2005, 07:38 PM   #1
bluprint
Member#: 75666
Default sti head swap
i am about to buy a v7 sti head set with the sti v7 ecu and would like to know the horsepower i might be makeing on a stock motor with just the heads and ecu and i would like to know if i would be able to rev to 8k with that set up on my stock wrx block. i have done a few searches and i have not really found the answers i have been looking for.
bluprint is offline   Reply With Quote
Old 04-25-2005, 08:48 PM   #2
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Honestly nobody knows. In my years here I've never even seen anyone whose done this. What is the rest of your setup? Sure you can rev it to 8k but it may not do you any good depending on what else you have done.
Old 04-25-2005, 09:16 PM   #3
sjl1614
Member#: 56791
06 OBS
I am in process of a swap also. I have a EJ257, with a Axis modded crank . It's now good for 8000rpm. So it should work well with my V7 heads. I would have to say "good luck" on revving the wrx crank that high more than a few times. At the least, have it balanced and get a Axis oil pump also
sjl1614 is offline   Reply With Quote
Old 04-25-2005, 09:21 PM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
The WRX crank is fine at that rpm.
Old 04-27-2005, 01:05 PM   #5
MrH00nel2
Member#: 80474
2002 Z06
1200whp
Subaru Stars
wrx can handle 8k with thoes heads. just no need to rev that high really if you dont have any other supporting mods.. its just a waste of gas. but thoes heads will open her up!
MrH00nel2 is offline   Reply With Quote
Old 04-27-2005, 03:19 PM   #6
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
giterdone
akcel is offline   Reply With Quote
Old 04-27-2005, 08:26 PM   #7
bluprint
Member#: 75666
i kind of just wanted to have a little more power and a longer power band, i was just planning on adding a downpipe and uppipe along with the heads. and you are sure the wrx block(stock) can handle 8000 rpm. i am thinking the the v7 fuel map would give it more power in the higher rpm considering it will have avcs. can i at least say it would give me about 20-30 whp from just the heads and ecu or is that too unrealistic.
FS : 07 Sti Heads hova Engine/Power/Exhaust 46 03-10-2011 06:29 PM
Will an 06' Sti Head Unit swap with an 07'? WRXPCT04 Car Audio, Video & Security 2 02-29-2008 04:47 PM
JDM v.7 w/ sti USDM head swap swift2fly Subaru Conversions 13 05-17-2005 08:28 PM
anyone swap 04 sti head lights for 05? BLCKTWRX Interior & Exterior Modification 3 06-12-2004 01:14 PM
STi cylinder head swap. KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-14-2002 12:06 PM
