Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 04-26-2005, 01:52 AM   #1
Jobey
Member#: 75679
Default my Front O2 sensor caused CEL, will I pass Emissions??
MY 2002 Impreza 2.5RS
I need to get emissions done this week..
don't really have the $$ or time this week to fix the CEL problem that was triggered by the front O2 sensor (code was found by dealer when scanned)
Anyone know if this would pass emissions??
Any tips to help it pass better? Run the cat HOT...use high octane gas..etc..
Jobey is offline   Reply With Quote
Old 04-26-2005, 07:07 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What state are you in? It depends on the emission inspection program in your particular state and locality. If they do an OBDII scan you will definitely fail, even if they don't you may still fail for the CEL.
Old 04-26-2005, 12:06 PM   #3
Jobey
Member#: 75679
I'm in Toronto, Canada..
Old 04-26-2005, 12:59 PM   #4
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Def. the _front_ one?
If so I'd have thought you'd have other issues besides emissions... did the dealer clear the CEL (and if so, why?) Do you have the actual code? Any mods?
I just passed Ontario emissions with a borderline P0420 _rear_ O2 code (basically on and off all winter - in fact came on again the day after the test), due to having only a single hi-flow cat. That's on a wrx where there's supposed to be 3. The NO and HC were still WAY below limits.
I don't know what would've happened if I'd had the code at the time of the test. I believe they use OBDII _at least_ to poll the cat temp - they told me mine was not up to temp when they hooked it up (despite a 25 min drive) and the machine made them go through a '3 min warm up' before taking the readings.
UkNuck is offline   Reply With Quote
Old 04-27-2005, 06:52 PM   #5
Jobey
Member#: 75679
Def the front one..
the code the dealer pulled up was P0130
cleared it...and hasn't came back
I went to get emissions...since the light was off...and passed..
bone stock car though..
Time to replace my front o2 sensor... BlkTS02 Normally Aspirated Powertrain 13 07-30-2011 11:36 PM
Front o2 sensor tool in MA? Emissions FAIL! segerton New England Impreza Club Forum -- NESIC 10 03-15-2010 05:59 PM
O2 sensor, will wideband pass emissions sciroccokid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-11-2008 09:50 AM
Is my front O2 sensor gone? thejean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 12-04-2006 12:12 AM
Screwed up my front O2 sensor the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 10 08-28-2001 12:48 PM
