Old 04-26-2005, 01:04 PM   #1
brcewane
Member#: 63990
Flat Grey
Default EVO MR "Vortex Generator" on a WRX
Hey guys,
I'm thinking of making my own "Vortex Generator" for the WRX out of fiberglass that would be like the EVO one seen here:
But without the antenna in it. What do you think?
...[Puts flame suit on]...
brcewane is offline   Reply With Quote
Old 04-26-2005, 01:11 PM   #2
WRXSIG
Member#: 83660
2013 WRX
Ice Silver
done right..itll look badass!
i wanted to look into getting one to see if it would fit but theyr like $250
WRXSIG is offline   Reply With Quote
Old 04-26-2005, 01:12 PM   #3
lianregnif
Member#: 30845
2003 WRX
what does a "vortex generator" do?
lianregnif is offline   Reply With Quote
Old 04-26-2005, 01:13 PM   #4
lawn boy
Member#: 16345
2003 WRX- Sold
E60 BMW 545i
I personally think that they're ugly
lawn boy is offline   Reply With Quote
Old 04-26-2005, 01:22 PM   #5
subieworx
Member#: 47769
It wouldn't do anything without being properly matched to the specs of the sti or other large wing. For esthetics only it is too Sonic the Hedgehog for me.
subieworx is offline   Reply With Quote
Old 04-26-2005, 01:36 PM   #6
fireball_jones
Member#: 67536
00 AW GM6
And a bunch of parts
Causes air to flow at a higher rate in a specific area, and used with a proper wing, should create more downforce.
Think of skyscrapers in a city, and how wind speed on the streets in between is greater than areas without skyscrapers. That's because they're giant vortex generators. You can use that channeled air to better create downforce or lift.
fireball_jones is offline   Reply With Quote
Old 04-26-2005, 01:46 PM   #7
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
Generates vortexes.
MB38 is offline   Reply With Quote
Old 04-26-2005, 01:50 PM   #8
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Originally Posted by MB38
Generates vortexes.
That would be "vortices".
-Porter-
TopSpeed is offline   Reply With Quote
Old 04-26-2005, 02:59 PM   #9
ibsailn
Member#: 79295
Default Not at all how they work
While it would be hard to argue that skyscraper do not generate vortices, this is not why it is windy between buildings. It is windy between buildings because a certain flowrate is being constricted thru the streets (acting as nozzles) and therefore the fluid (air) is accelerated. This is also not a good description of how the vortex generators create more flow to the wing.
We often use votex generators in model testing in my business (yacht design). We use them for slightly different reasons, but the theory is the same. The best layman explanation is similar to the dimples on a golfball. By generating vortices (turbulance), the flow stays attached to the surface longer and therefore drag is reduced. Also, in the case of the rear of the car, keeping the flow attached to the rear-sloping roof will help keep high velocity flow on the rear wing.
As far as having them be effective on a WRX, your guess is as good as mine. There is a parasitic drag caused by the vortex generators, so that would have to be overcome thru improved flow for them to be worthwhile. Whichout wind tunnel testing, it would be hard to know if they are helping or hurting.
ibsailn is offline   Reply With Quote
Old 04-26-2005, 03:49 PM   #10
ranger5oh
Member#: 77752
5Sti 2005 Sti
Best way to describe vortices: They mess up the airflow... the "sloppy air" , just as ibsailin says, stays attached to the surface. Flow that seperates from the surface doesnt provide the correct aerodynamics for optimum downforce and minimum drag. This is the same reason fighter jet intakes are a few inches off the surface of the fuselage of the jet. (Note, I am an aero engineer for a military aircraft company)
Anyway, I dont thin kthis guy is interessted in the performance of them, nor am I. I love the look , and if you make a good set, I would be interested in buying one off you.
Thanks,
ranger5oh is offline   Reply With Quote
Old 04-26-2005, 04:15 PM   #11
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
as i knew it when i first saw these vortex generators... give it a few months, every civic will have one. I dont think it will be worth anything for your car, dont bother
KAX is offline   Reply With Quote
Old 04-26-2005, 04:46 PM   #12
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
(Slight tangent) So going forward with the thought on what a vortex generator would be used for on a car; it wouldn't make sense with an STi from what I can gather. I tend to believe that the point of the STi wing is less about downforce and more about lowering the overall drag coefficient by smoothing out the air. So disrupting the air even more before the STi wing would make the wing less efficient for its intended purpose. At least that is the way I am interpreting things. (off tangent)
So what is the point of the WRX wing? I would tend to believe it is closer to improving downforce than lessening drag. However I don't know that it sits high enough to catch and benefit from the vortex generated air flow. It would certainly be interesting to see in a wind tunnel, but that is the problem that I believe a wind tunnel would be the only way to know and they ain't happening.
offset
offset is offline   Reply With Quote
Old 04-26-2005, 04:49 PM   #13
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Originally Posted by brcewane
Hey guys,
I like the idea and would love to see how it comes out.
~v6
V6TurboTA is offline   Reply With Quote
Old 04-26-2005, 04:50 PM   #14
Handsdown
Member#: 29355
subaru's already working on vortex generators...
Handsdown is offline   Reply With Quote
Old 04-26-2005, 05:01 PM   #15
volleybrad
Member#: 58860
2004 WRX
Aren't those made by Adobe?
volleybrad is offline   Reply With Quote
Old 04-26-2005, 05:07 PM   #16
WRX450
Member#: 20867
Default too bad
That wasn't even a valiant attempt at a photo manipulation...
WRX450 is offline   Reply With Quote
Old 04-26-2005, 05:54 PM   #17
Handsdown
Member#: 29355
you're right, it was a photo manipulation with intent of horseplay and general silliness... sorry i'm not valient enough for you!
Old 04-26-2005, 08:40 PM   #18
fireball_jones
Member#: 67536
00 AW GM6
My bad, half way through typing that my brain mixed up vortex and the venturi effect
I've never read anything that said they had any definite effect on the Evo, let alone what they would do to an STi. But they do look cool.
Old 04-26-2005, 08:43 PM   #19
flicky30
Member#: 74117
2004 VW R32
Black Metallic Pearl
That is THE MOST rediculous photochop ever. Wow, that's one I'll have to "right click and save picture as"
flicky30 is offline   Reply With Quote
Old 04-26-2005, 10:37 PM   #20
Golfa
Member#: 21394
Sold 2004 STi
08 WW Evo X
i like the wrap-around taillight effect
Golfa is offline   Reply With Quote
Old 04-26-2005, 10:47 PM   #21
JIN
Member#: 27731
They actually made vortex g for the subies. In fact, I have seen a couple of them around in the subies here in Singapore. Even saw one in carbon fiber too ... really nice.
Jin
JIN is offline   Reply With Quote
Old 04-26-2005, 10:50 PM   #22
moss
Member#: 10197
Jin
Its your job to get a picture any for the GCs
keith
moss is offline   Reply With Quote
Old 04-26-2005, 11:02 PM   #23
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
You couldn't be more wrong, sorry!
Vortex generators generate tip vortices that trail behind them. What this does essentially is delay boundary layer separation, and thus delays stall. On an airplane wing, they are no more than small fins of aluminum. In fact, this would probably be more effective than these "thicker" ones. But the idea is the same. Having these on a car has a similar result as a spoiler in that location (like on the back of SUVs). Basically, it keeps the air from seperating as much, decreasing drag (the majority of drag on an object is the result of flow separation on the back)
twizzstyle is offline   Reply With Quote
Old 04-27-2005, 02:34 AM   #24
kheovnien
Member#: 79025
2004 WRX
ya, and adobe lost money on this investment, thus the small number produced.
kheovnien is offline   Reply With Quote
Old 04-27-2005, 02:48 AM   #25
MikeBuzzsaw
Member#: 66443
2011 Toy-OTAAAA
four-runner!
Its like communism. In THEORY, it will help you reduce drag, but in real life, no1 has seen an increase in anything.
MikeBuzzsaw is offline   Reply With Quote
will evo ix mr wheels fit on a wrx dontgiva Tire & Wheel 1 01-10-2008 10:56 PM
Anyone running a stock evo twin scroll turbo on a wrx? mcu81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-09-2006 11:29 PM
Evo MR intercooler on WRX????? tigeracer Subaru Conversions 4 07-13-2005 12:59 PM
my 05 Evo MR versus my own 03 WRX 280whp dyno Dynamic sonicowrx03 Proven Power Bragging 48 05-07-2005 10:11 AM
Anyone put the Evo 8 16g twinscroll on a WRX/STi? jefersun Proven Power Bragging 32 03-30-2004 12:50 PM
