Old 04-26-2005, 04:03 PM   #1
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Default Parts to convert 04 STi suspension to 05?
Anyone compile a listing of the parts that differ between the two model years?
The pad knockback on the small pliable 04 hubs has gone from annoying on the track to downright dangerous on ths street. It is at the point now that if I haven't hit the brakes in a while I get a full pedal strock with no pad contact on the rotors until a second strock.
turboICE is offline   Reply With Quote
Old 04-26-2005, 04:16 PM   #2
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
not sure but heres a quick list of what i know:
front:
control arms
hubs
rear:
knuckle
hub
lat links
struts
the front might need a kuckle and strut too but im not sure
YaZahX is offline   Reply With Quote
Old 04-26-2005, 04:42 PM   #3
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
About what I would expect. The knuckle on the front is likely as well. Surprised on the rear strut, hadn't thought that would be changed.
Old 04-26-2005, 05:10 PM   #4
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
all 4 struts were changed in the 05(they are black now), i belive the distance of the bolt holes in the rear strut to knuckle was made wider.
Old 04-26-2005, 07:52 PM   #5
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Ahh ok, also not the least of which other parts are the rotors and wheels.
Old 04-26-2005, 11:34 PM   #6
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
ya know if u just want the 5x114 all u have to do is swap the hub itself...(and rotors)
im pretty sure the bearings are the same...
Old 04-26-2005, 11:48 PM   #7
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Sounds to me you have a bad bearing or loose axle nut. If the hub was giving enough to cause pad backout it would break from fatigue in no time.
Scoobie Steve is offline   Reply With Quote
Old 04-27-2005, 12:07 AM   #8
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Oh it is very likely at this point the bearing is bad (though Wayne Subaru says it is fine) - but the knockback has incrementally got worse ever since I got the car. Two other '04s I know personally have been experiencing the exact same progression of knockback. Not so much the hub giving as the hub flexing incrementally more and more on the bearing - which by now I am sure is well worn.
I would have thought that they would have put bigger bearings on with the larger hubs. Maybe I am just asking too much of the front bearings and I just need to accept that they will be a frequent wear item instead of just a wear item.
Old 04-27-2005, 12:30 AM   #9
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
they might have changed the bearings
call a dealer and ask the the parts dept to see if the bearing for the 04 and 05 are the same
Want to Convert My 02 Bugeye to 04-05 Front end. KassanovaSTi Interior & Exterior Modification 74 07-04-2008 11:28 PM
04 STi Suspension on 05 WRX problems Uncle Tattoo Brakes, Steering & Suspension 4 05-23-2008 10:56 PM
OEM 04 STI suspension into 05 WRX wagon javi-sti Newbies & FAQs 3 11-05-2007 02:17 PM
IL: WTB 04-05 STi headlights or parts to convert my WRX lights to HIDs Ace009 Private 'Wanted' Classifieds 2 08-11-2006 01:50 PM
how to swap 04 STi motor into 05 WRX? whateverwrx Newbies & FAQs 4 05-22-2006 01:48 AM
