Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 04-26-2005, 04:17 PM   #1
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
Default Tales from the Dyno: Wayne's super-strong Stg 0 WRX
02 WRX with Stg 0 kit (up-pipe, pulley and reflashed ECU). Made a surprising 210whp through custom tuning. That's 10whp more power than a stock EVO
Vishnu Performance is offline   Reply With Quote
Old 04-26-2005, 08:11 PM   #2
Kantalias
Member#: 50800
2004 Impreza WRX
Platinum Silver
Hey, can someone answer a stupid question? How do you know which line on a dyno plot corresponds to which vertical axis? Obviously in the case of the first plot in this tread (y-axis for HP = y-axis for torque) this is a non-issue. But in the case of PSI and AFR in the second plot, which is which? Do you have to know enough "engine dynamics" to know which curve *should* have which characteristic or is there some feature that I'm overlooking?
Thanks!
Kantalias is offline   Reply With Quote
Old 04-26-2005, 08:34 PM   #3
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
Thanks!
Well, if you look at the lower line on the boost and A/F plot you will notice it starts at 13, then moves down to 11 as the RPMs get higher, this is the A/F. Look at how much higher the boost level is (16 PSI, then moving down to 12) those numbers (boost and A/F) are pretty far away, it's not like the boost on this setup would be as low as 11 PSI, or the A/F would be as lean as 16 You can also tell by the way the line is drawn on the graph, The boost line will always Increase upwards, then fall off a bit, and the A/F will be underneath it. oh ya, no qustion is a stupid question
--Kim @ Vishnu
Old 04-27-2005, 01:30 AM   #4
DaBoxerman
Member#: 79019
Hey Vishnu Performance - Any special deal on tuning for Nasioc members? Might be interested in getting the reflash and some tuning - PM me the details
DaBoxerman is offline   Reply With Quote
Old 04-27-2005, 01:59 AM   #5
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
only if ya got a 2.5L turbo . Seriously though, they have a deal for the 2.5L turbos.
Drews_WRX is offline   Reply With Quote
Old 04-27-2005, 03:28 AM   #6
2phless
Member#: 69343
1998 TransAm cnvrtbl
edit: misunderstood post.
2phless is offline   Reply With Quote
Old 04-27-2005, 08:23 AM   #7
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Impressive numbers for a Stg0 Shiv! Freak maybe?
What does the Stg 0 usually dyno on the DD?
Need4Boost is offline   Reply With Quote
Old 04-27-2005, 12:47 PM   #8
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
Right around 200whp. So an extra 10% at the wheels is pretty surprising. Pleasantly surprising of course.
Shiv
Old 04-27-2005, 01:20 PM   #9
Kantalias
Member#: 50800
2004 Impreza WRX
Platinum Silver
--Kim @ Vishnu
Cool. Thanks for the explanation.
Old 04-27-2005, 03:31 PM   #10
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
Sent you a PM
--Kim @ Vishnu
Old 04-28-2005, 11:49 AM   #11
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Shiv
5%
cdvma is offline   Reply With Quote
Another tale from the IT front . . . banman Off-Topic 33 05-14-2008 07:34 PM
4/18/05 Tales from the Dyno: 05 Sti Stg 2 kicks butt Vishnu Performance Engine Management & Tuning 25 05-04-2005 04:28 PM
Tales from the Dyno: Davon's WRX with GT3040 turbo Vishnu Performance Engine Management & Tuning 12 04-27-2005 04:25 PM
Tales from the Dyno: Pet's GT30R'd STi-- 500bhp! Vishnu Performance Engine Management & Tuning 0 04-26-2005 04:16 PM
twilight zone, tales from the darkside. enozto Off-Topic 4 08-22-2003 11:11 AM
