Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 04-26-2005, 05:22 PM   #1
Rick539
Member#: 35997
Default Ver 7 and UTEC
I know I am going to get slammed about using the search engine. But I just want to get conformation. Putting a ver 7 in my 03, I can use my utec for it right? Just want to make sure there are no conflicts.
Rick539 is offline   Reply With Quote
Old 04-26-2005, 05:59 PM   #2
norexyet
Member#: 39149
11 elantra
yea i said elantra
I believe so, depends on who wires it and there skills i imagine. If the wiring is kinda shady id go with stand alone. But i talked to rich (ver III) through pm's on here and he said that i would be able to run a utec on a ver 7 when he was done with the swap. So ill see how it works out.
norexyet is online now   Reply With Quote
Old 04-26-2005, 06:08 PM   #3
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
utec is piggy back whats there to wire...
i wanna knwo if i put the utec on my car(version 7) would the avcs work and what version do i use?
YaZahX is offline   Reply With Quote
Old 04-26-2005, 06:39 PM   #4
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
UTEC's work great with STi ECU's. I've been running my UTEC with a Version 7 RA Spec C ECU (AG970 I think) for almost 2 years now.
The only issue that there was, the AVCS wires were not passed through on the US UTEC. The solution, get an Australian model UTEC that is AVCS compatible.
US UTEC's can be wired to work with AVCS, but its plug-n-play with the AUS STI model UTEC. You want an AUS UTEC, contact Turbo XS, they'll gladly get you one.
def
dug-e-fresh is offline   Reply With Quote
Old 04-26-2005, 06:44 PM   #5
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
def
so if i get the AUS one, plug it in and im done ?
cool, thanks for the info!!
(search terms: jdm sti utec avcs piggyback)
Old 04-27-2005, 02:37 PM   #6
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
If you have the entire car harness ran...
def
Old 04-27-2005, 03:27 PM   #7
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
def
the harness is from the jdm7
only part that was spliced were the parts that go to the dash harness... anything that ran to the motor was left in 1 peice
Old 04-27-2005, 04:20 PM   #8
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
Then your good
def
Old 04-27-2005, 04:24 PM   #9
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
also, the newest wrx style utecs, revision 6b, have the wires for avcs included, so u can use that.
im running a v8 jdm ecu with us wrx utec rev 6b
ImprezaRSfan! is offline   Reply With Quote
Old 04-27-2005, 04:52 PM   #10
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
the one I just picked up 2 weeks ago still has the "AUS STI" decal on it, and I was told that was the last one they had
def
Old 04-29-2005, 12:29 AM   #11
Mumbles
Member#: 248
Yeah i've been running my non-sti rev6b utec for awhile now, no complaints. Great product netted me 30WHP.
-b
Mumbles is offline   Reply With Quote
Old 05-02-2005, 12:40 PM   #12
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Are you guys getting check engine lights?
garface is offline   Reply With Quote
Old 05-02-2005, 01:17 PM   #13
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
You will not get a CEL if you wire it in correctly, the AVCS that is. The UTEC will not cause a CEL, provided it is the right revision as mentioned above.
Jarrad
PDXTuning is offline   Reply With Quote
Old 05-02-2005, 02:07 PM   #14
garface
Member#: 1581
MY00 RS/STi7
I thought that the JDM engines got a CEL because of the injectors or something like that. No?
Old 05-02-2005, 02:16 PM   #15
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Thats what I was told.^
DoctorNick is offline   Reply With Quote
Old 05-02-2005, 02:24 PM   #16
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
I have a JDM/AUS UTEC and a twin scroll ECU in my car, I get NO CELs.
Old 05-03-2005, 04:16 PM   #17
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
There were UTECs that would give you misfire codes when used with JDM ECUs, the newer UTECs do not do this.
def
Old 05-03-2005, 04:17 PM   #18
garface
Member#: 1581
MY00 RS/STi7
def
But rev6b will, right?
Old 05-03-2005, 04:22 PM   #19
cronic
Member#: 9749
The mis information in this thread is crazy..haha
Rev 6b usdm utec, lets avcs pass through, no wiring, get 4 injector cel's
Aus utec, lets avcs pass through, no cels
I ran 6b in my v7 swap, with no problems other then the CEL which i turned off anyway..
cronic is offline   Reply With Quote
JDM Ver.7 and 8 ECU with ECUtech Lisence CHEAP Dugansti Engine/Power/Exhaust 1 10-17-2009 11:04 PM
Ver.7 and Ver.8 into 02'-05' AVCS wiring diagram DS1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-17-2008 02:06 AM
FS NY: JDM STi Ver. 7 ECU and TXS UTEC garface Engine/Power/Exhaust 28 08-28-2008 02:43 PM
COMPELTE JDM VER-7 and VER-8 drivetrains, etc.. .... FLAT4motorsports Engine/Power/Exhaust 19 05-31-2006 09:43 PM
