Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 04-26-2005, 06:05 PM   #1
snowjob
Member#: 59357
2009 Forester XT
Default EJ20G Timing belt Which one do I use????
So I've decided to do the timing belt on my ej20t and just want to confirm I'm doing everything right.
BeforeI took the belt off, the turbo side cams both exhaust and intake were not really lining up, they looked off by about a tooth.
Here is what I did, If i've made any mistakes, please correct me before I start her up.
1. took the plug out of cyl. #1 and put a compression guage in their.
2. turned the crank via the front crank bolt until I started to get compression on the guage, then lined up the marks on the crank with the block.
3. took off the idler pulley
4. took off the tensioner(at which point **** hit the fan and both intake cams moved because of the tension taken off the pulley)
5. Using the manual, I rotated the cams back to where they should be, making sure to only turn them the way the book indicated.
6. So here is where I'm at right now, the turbo side exhaust and intake cams cyln 1,3 have no pressure on them, as in they are not pushing any valves down, but the other side, ie. cyl #2,4 cams are under pressure, as in they are pushing down valves.
Is this correct?
Also, what timing belt should I use. will a wrx work?
Thanks for any tips I may have missed.
Frazer
snowjob is offline   Reply With Quote
Old 04-27-2005, 10:49 AM   #2
snowjob
Member#: 59357
2009 Forester XT
anybody?
Old 04-27-2005, 11:24 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Old 04-27-2005, 12:03 PM   #4
snowjob
Member#: 59357
2009 Forester XT
Cool, thanks, That settled my nerves a bit. What belt did you use on your ej20 Jaxx?
Thanks
Frazer
Old 04-27-2005, 09:17 PM   #5
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
the belts on an EJ20G are the same way as on the DOHC 2.5rs.
THe ones on the EJ207 are like the ones on the USDM WRX.
snowman4us is online now   Reply With Quote
Old 04-27-2005, 11:46 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i used the 98 RS timing belt
Old 04-28-2005, 08:26 AM   #7
snowjob
Member#: 59357
2009 Forester XT
Thanks Guys you've answered what I needed to know.
Old 04-28-2005, 11:08 PM   #8
mykrrrr
Member#: 733
'13 Focus ST
I used a WRX one.
-mykr.
mykrrrr is offline   Reply With Quote
ej20g timing belt golf_o Pre-2002 Factory Turbo Powertrain 21 08-18-2010 03:48 AM
ej20g timing belt writeup? GripGC8 Pre-2002 Factory Turbo Powertrain 3 11-23-2007 04:51 PM
EJ20g timing belt tensioner? tweakling Subaru Conversions 7 01-09-2007 02:19 AM
ej20g timing belt shatowz Subaru Conversions 7 02-16-2006 01:25 PM
EJ20G timing belt questions scoobyimprza Subaru Conversions 3 03-20-2005 11:52 PM
