Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-26-2005, 08:33 PM   #1
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
Default Did some reading about AWD and changing tire sizes.
Well I read that in an AWD car you cannot change the rims size and specially do not change the diameter of the actual wheel (tire and rim) since it could affect the AWD system.
BajaT05 is offline   Reply With Quote
Old 04-26-2005, 08:59 PM   #2
bajabob
Member#: 73236
2003 Baja
Baja Yellow
I don't think its so much changing tire or rim size as mixing different sizes that causes problems. I am running non stock rims with 225/55-17 tires with no problems. I know if your running the donut spare you have to put the baja in FWD mode with the fuse so the center diff doesen't toast.
Bob
bajabob is offline   Reply With Quote
Old 04-26-2005, 09:04 PM   #3
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
Well that was just what I read and I wanted to share.... I know that different tires is NO-NO, all tires must be the same, but then I read this that the system may suffer if different tire diameter are used. The rims arent that bad but one must keep the overal diameter the same.
Old 04-26-2005, 10:11 PM   #4
Hawk296
Member#: 14555
1995 Impreza L
Baja
And if you have a flat tire in the rear, Its a pretty good idea to take a full size front wheel, put it on the rear, then put the spare on front. It keeps the rear limited slip dff. happy.
Hawk296 is offline   Reply With Quote
Old 04-26-2005, 11:04 PM   #5
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
I know the Volvo 1998-2000 AWD systems are very sensitive to tires and tire pressure. Tires with significant tread depth difference can cause undo stress on the angle gear. When Volvo switched to the Haldex AWD system the sensitivity lessened as well as some of the AWD issues of the previous generation system.
As long as the diameter is equal at all four corners and unless you alter the angle of the driveline components, i don't see how you could damage the AWD system, whether that is with 15, 16, 17 or 18" wheels. Manufacturers offer wheel upgrade options and they do not alter the AWD systems to compensate.
02_Forester is offline   Reply With Quote
Old 04-28-2005, 08:07 AM   #6
baja03
Member#: 83018
2003 Baja
dark blue
i have had a few 4WD and this is my first AWD but i have never heard that tire size is bad for the diff. I do know if you put bigger tires it makes the engine work harder to turn the tire which can cause the engine to not last as long as if you were running stock rim and tire size and i know if you put to big of a rim on your auto it can cause the brakes to over heat and worp the rotor.
baja03 is offline   Reply With Quote
Old 04-28-2005, 09:22 AM   #7
KC
Member#: 442
2013 Crosstrek XV
00 Honda S2000
As others have said... you don't want to mix diameters on the same car (ie: borrow a tire from someone that is not the same diameter).
Ideally, you'd want the same diameter as the stock wheels for your replacements. Example: WRX Stock tire is 205/55-16. A 225/45-17 wheel/tire combo is the same diameter (as close to stock as you'd get in any plus size) as the stock wheel/tire combo.
It's also good practice (that someone said) that if you blow a rear tire, take one off the front and put it on the rear.
As long as all 4 tires/wheels are the same there'd be no issues. At all.
KC is offline   Reply With Quote
Old 04-28-2005, 05:57 PM   #8
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
You can run 27" rimz yo as long as you run four o them! W3rD
Samirr76 is offline   Reply With Quote
Old 05-04-2005, 04:03 PM   #9
wagman01
Member#: 3894
2002 WRX Wagon
Battlewagon Black
Having mixed diameter tires/wheels is very bad news for the AWD system. But if you change the diameter of ALL FOUR at the same time, you will not harm anything. Your speedometer reading will be off, but that's about it.
If you need to run with a spare and you have an Automatic transmission, make sure you install a fuse into the FWD fuse holder in the engine compartment. This will make your Baja front wheel drive until you can get the tire fixed. This is all outlined in your Baja's owner's manual.
wagman01 is offline   Reply With Quote
Old 05-04-2005, 04:22 PM   #10
ranger5oh
Member#: 77752
5Sti 2005 Sti
As long as all 4 are the same diameter it doesnt matter how big they are. You could run tractor tires on the mofo if you want. All the driveline will see is slower moving wheels.
ranger5oh is offline   Reply With Quote
Old 05-11-2005, 08:23 PM   #11
RacingBlue
Member#: 3325
The ABS tone generators will be off with a differant size tire diameter (all 4 of course) May mess up the TCU as well and shift wierd in an auto. Gas mileage will most likely drop. Why spend money to screw it up? Do that stuff with grandpa's 55 Chevy.
RacingBlue is offline   Reply With Quote
Old 05-12-2005, 08:22 AM   #12
TurboBaja
Member#: 72618
2005 Baja Turbo
Garnet Pearl
Since these vehicles have LSD's different size tires will cause the clutches to slip, creating heat and wearing out the diff clutches after a while, no more LSD . The 4WD vehicles you had previously probably had open diff's and it wouldn't matter. If you had a system with part-time 4WD that locked the diffs., you may recall that that was for 'offroad use only' use on tarmac would cause the system to bind because the tires couldn't slip the way they would on dirt/gravel...
TurboBaja is offline   Reply With Quote
Old 05-12-2005, 08:41 AM   #13
KC
Member#: 442
2013 Crosstrek XV
00 Honda S2000
Not in my Baja Automatic. Nor in the new Legacys either. There's no fuse to pull to disable the AWD.
I can't pinpoint when they got rid of that 'feature'.
--kC
Old 05-12-2005, 01:17 PM   #14
Samirr76
Member#: 4835
2003 Baja 5MT
You dont PULL a fuse you INSTALL a fuse to disable the AWD. It only works for non-turbo automatic subaru models. Will not work on 5MT or 4EAT-T. We never got rid of the AWD-disable feature.
Old 05-12-2005, 05:29 PM   #15
cliffhanger
Member#: 80446
2005 5spd Baja-T
370+405=new clutch
i dont understand-- i cant change the tire size at all, even when all 4 of the tires are kept the same o.d.?
cliffhanger is offline   Reply With Quote
Old 05-12-2005, 06:59 PM   #16
RacingBlue
Member#: 3325
You INSTALL the fuse to disable the Auto AWD for testing etc.
Changing the tire diameter much (circumferance) changes the tone generated by the tone sensors thus sending an error signal to the ABS system. A larger dia. would tell the ABS you are going a differant speed than you actually are. Ditto the TCU (Trans Control Unit) in an auto. If the O.D. is same as the OE tire your fine.These cars are not like Uncle Jake's Fordson tractor. Factory tolorance in circumferance for worn tires is 1/4 inch. Any more you will tend to screw up the center diff or limited slip if yours is equipped with one. In other words you should not install a new tire with a set of three that are 3/4 worn out.
Changing tire size- ? for RS guys- ImprezaL Brakes, Steering & Suspension 19 09-04-2005 11:39 AM
Did some reading on Utecs...Need your opinions m4r10 Engine Management & Tuning 4 04-27-2005 05:03 PM
New here need some questions about AWD cars. Imprza Newbies & FAQs 11 12-19-2003 02:16 AM
Changing Tire Size from 215/45/17 to 225/45/17 2.2gotboost Tire & Wheel 1 08-28-2003 12:43 PM
changing tire size affects TOM MAC Brakes, Steering & Suspension 6 08-13-2002 12:28 PM
