Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-27-2005, 09:39 AM   #1
Road Toad
Member#: 49777
04 Turbo Blk/Blk
01 BMW M Coupe Blk/Blk
Default Preparing to "fix" rust on emergency brake drums
I bought some aerosol rust converter and some high temp (1000 degree) metallic aluminum spray paint. I'm planning to remove the rear wheels, unbolt the calipers, sand the drums with several grits, tape off the contact surfaces, prep with alcohol, spray several quick consecutive light coats of converter, wait overnight, spray the calipers and drums a couple times with the high temp paint, wait 4 hours and reassemble.
I've worked on lots of disk and drums brakes before; anything unusual about the Baja? I'm thinking of putting converter on the edges of the rotors where most show rust. Pros or cons? Thoughts and ideas welcome.
John
Road Toad is offline   Reply With Quote
Old 04-27-2005, 01:28 PM   #2
Hawk296
Member#: 14555
1995 Impreza L
Baja
I do pretty much the same thing. I spray the inner hub/hat area, and also the outside edge.
Hawk296 is offline   Reply With Quote
Old 04-29-2005, 07:37 PM   #3
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
take your calipers off the bracket, pull your pads off, pull the rotor off, then paint. Use a bunji cord to hang your caliper so it doesn't hang on its own rubber hose.
Be sure your rotors are clean when you're done. Use brake clean to remove your finger prints and whatever else you slobber on them.
I like glossy black calipers but my Jetta came with red calipers, its ok. Usually they're noticably dirty.
gitRdun!
Chris N is offline   Reply With Quote
How bad is this Rust on my Brake Cylinder? Chandy69 Brakes, Steering & Suspension 2 05-18-2008 12:44 PM
EU prepares to lay smackdown on Chinese goods Wagon Of Fury Off-Topic 1 09-17-2007 05:17 PM
Fixed rust on e-brake drum (m) Road Toad Baja Forum 3 07-18-2005 06:50 PM
would like a link to "how to" on drum to disk brake conversion trd20 Subaru Conversions 2 06-05-2004 11:32 PM
How to remove rust on coilovers? Rally Punx Brakes, Steering & Suspension 7 02-25-2004 12:19 AM
