Old 04-27-2005, 03:12 PM   #1
tellravi
Member#: 40409
Default 02 WRX - Hesitation at 5000 RPM
Folks
I have a 02 WRX, when I hit 5K RPM sometimes, it sense a little hesitation just for a second and then it continues. This is not consistent but started to happen over the last two mts.
Any ideas on where I should look.
The car is stock with no modifications. I use 93 OCT fuel in it.
Thanks
[email protected]
tellravi is offline   Reply With Quote
Old 04-27-2005, 04:40 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
Is it while pushing the throttle really hard, or just at part throttle? If it's at part throttle, it sounds normal to me. As far as I know, the stock ecu changes the way it fuels at 5000rpm while at part throttle. This is what I'd bet is causing the hesitation.
peace
Old 04-27-2005, 08:21 PM   #3
tellravi
Member#: 40409
If that is the reason, why wont it happen everytime it hits 5K RPM
Thanks
Old 04-27-2005, 08:35 PM   #4
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
actually, the ecu changes fueling around 4500RPM, no 5k. I'd recommend getting someone to log your ECU to get some more info about the problem.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 04-27-2005, 10:34 PM   #5
j-wrx
Member#: 14180
2002 Stg.1 WRX Wagon
Platinum Metalic Silver
I had a similar problem, but after installing the Cobb AccessPort (stage 1 91 oct) the problem was gone. Now the power is consistent and smooth all the way through the power band.
j-wrx
j-wrx is offline   Reply With Quote
06 WRX Hesitation between 3000 RPM - 5000 RPM dao Newbies & FAQs 11 01-19-2012 11:56 AM
Hesitation at 5000 rpms? 02blueru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 112 04-03-2008 01:45 PM
stg 2 wrx boost at 5000 rpm mattj02wrx Engine Management & Tuning 7 01-28-2007 01:07 AM
02 wrx acts like it shuts down at 5000 rpms and stutters bad brettedmonds Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-16-2005 10:49 AM
Hesitation at 5000 rpm feropont Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-24-2004 12:33 PM
