Old 04-27-2005, 05:47 PM   #1
DarkShadow
Member#: 17615
2009 Toyota Tundra
Default Wide band??
I ordered an air/fuel gauge. I heard that it is pretty useless to use it with the stock rear O2 sensor. Can I just get any wide band sensor and hook it up?
DarkShadow is offline   Reply With Quote
Old 04-27-2005, 08:38 PM   #2
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
your standard a/f gauge is nothing more than a voltmeter in the range of 0-1v. A wideband sensor operates in the 0-5v range, but most wideband controllers have a standard 0-1v output that you can use to run a standard a/f gauge.
Equilibrium Tuning is offline   Reply With Quote
Old 04-27-2005, 10:54 PM   #3
DarkShadow
Member#: 17615
2009 Toyota Tundra
so i should just save up for a wideband controller or something of that nature.
Old 04-28-2005, 01:24 AM   #4
2phless
Member#: 69343
1998 TransAm cnvrtbl
Look into the LM-1 from innovate motorsports. Unless you plan on going with a specific EM at some point, then check out their options for W/B. The UTEC with a Tuner is a nice setup with easy to read logs.
The LM-1 has good software and some nice add ons for data logging.
The narrowband AFRs are not totally worthless. I use mine tapped to the rear O2 to double check my wideband results. If the WB sensor goes bad, it's good to know the super lean (for example) reading isn't accurate since the AFR gauge is still reading over rich.
2phless is offline   Reply With Quote
Old 04-28-2005, 03:01 PM   #5
lowblow
Member#: 56902
2009 VW Jetta SE
You could use a wideband to narrow band adapter with the A/F gauge so that it is less of a light show...
lowblow is offline   Reply With Quote
Old 04-28-2005, 11:46 PM   #6
XtianLA
Member#: 29958
03 WRX
I was playing with my LM1 today. I really like it and I'd definitely recommend it to anyone looking into a wideband.
XtianLA is offline   Reply With Quote
Old 04-29-2005, 01:39 AM   #7
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
the LM1 is deffinately nice. I use one for all of my road tuning customers. The Zeitronix unit is a also a good, cheaper alternative that works well if you're going to install it to be in the car at all times. The LM1 is a little large for a good permanent install IMO.
Old 04-29-2005, 02:16 AM   #8
vividracing$ucks
Member#: 86088
i agree
vividracing$ucks is offline   Reply With Quote
Old 04-29-2005, 07:58 AM   #9
lowblow
Member#: 56902
2009 VW Jetta SE
I have a Twin Tec WEGO installed in the clock gauge pod...
Wide band vs narrow band O2 mitch808 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 06-12-2002 04:13 PM
('93-'01) Wide band O2 sensor voltage range jeffg Impreza Forum 5 06-05-2001 02:26 PM
New Info about my00 wide band o2 sensor??? skidplatez Normally Aspirated Powertrain 3 11-03-2000 11:08 PM
Wide band O2 on stock ECU? HamFist Normally Aspirated Powertrain 1 10-30-2000 04:35 AM
Wide-band A/F Guages? 8Complex Normally Aspirated Powertrain 3 10-18-2000 10:51 AM
