Old 04-27-2005, 10:46 PM   #1
car_cursed
Member#: 85327
More projects than
you can shake a stick at.
Have a Nice Day? Dastec Programmer
I have a Dastec on my car, I know it is old. but I bought the car with it. i am having some problems with it. I bought the car in california, and the car was tuned in texas, anyhow I brought the car back to Salt Lake City where I live and the car will not boost above 10-11lbs it was boosting 14-15 in california and was fast. now it isn't so much, any ideas? could it have started to bleed boost? It has an ihi vf29 upgraded tmic, and bov, and downpipe. any help other than go to cobb and give them $1500 for an accessport and tuning would be great, they also recommended against just adding a boost controller.
car_cursed is offline   Reply With Quote
Old 04-27-2005, 11:47 PM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
call modern garage in SLC
Old 04-28-2005, 01:01 AM   #3
car_cursed
Member#: 85327
More projects than
since they are in bed with cobb they have the same opinion as cobb.
Old 04-28-2005, 01:14 AM   #4
ImportVenom
Member#: 34204
2004 WRX
WR Blue
Could it just be the elevation in SLC? Maybe you just need it retuned for the elevation (approx 4000+ feet?).
ImportVenom is offline   Reply With Quote
Old 04-28-2005, 01:26 AM   #5
car_cursed
Member#: 85327
More projects than
that is it, but how can i retune it? i do not have the software, not sure if I can get it. so I am stuck probably will break down and buy a utec or accessport. some time.
Old 04-28-2005, 12:52 PM   #6
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
did you call and talk to christian about tuning an unichip?
your still looking at $4-500 for a dyno tune any way
Old 04-28-2005, 03:44 PM   #7
car_cursed
Member#: 85327
More projects than
they won't tune it. they will only tune the accessport. and i am not a big fan of dyno tuning. would rather street tune. more realistic.
Old 04-29-2005, 11:32 AM   #8
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
well then the next closest place i can think of is matrix in portland or some where in denver
more realistic ..sorta
a load based dyno like the mustang is significantly different than say a dynojet that you can produce partial loads and there by tune for them.. the mustang uses magnetic resistance vs weight resistance
OT LOCAL: Hiring programmers SFsube Bay Area Impreza Club Forum -- BAIC 2 08-14-2001 01:47 AM
Subaru ECU programmable? Godmal Factory 2.0L Turbo Powertrain 11 06-04-2001 12:32 AM
AFC w/ programmable user pre-sets Imprezd Normally Aspirated Powertrain 0 01-25-2001 04:33 PM
Programmable ECU vs. Piggyback Electronics 8Complex Normally Aspirated Powertrain 78 10-24-2000 07:37 PM
Programmable ECU's... what kinda options out there? 8Complex Technical Forum Archive 25 07-07-2000 12:49 AM
Message Board Statistics All times are GMT -4. The time now is 01:00 PM.
