Old 04-28-2005, 03:23 AM   #1
2002GX
Member#: 86028
Default 2002 GX Differential Swaps???
I am wondering if there are any more aggressive differentials (higher ratios) available for my car. My car is a slow accelerating contender (around 10.2 )-60) and I'm try to shave 2 seconds off. Thinking of doing a WRX Standard Exhaust, Cold Air Intake, and maybe cams. In the past I've had slow cars (ie, BMW 318) that a shop swapped the differential for another one, and presto literally shaved 2 seconds off 0-60, ok so I topped out 15-18 mph less, i don't care.
Paul
2002GX is offline   Reply With Quote
Old 04-28-2005, 12:37 PM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
i am not even sure what a GX is ?
Just got my rear differential swapped out under warranty.... what could this sound be innova Brakes, Steering & Suspension 5 01-12-2007 08:15 PM
Help! Differential Swapping to LSD 1wiwrx Transmission (AT/MT) & Driveline 3 08-16-2006 06:58 PM
todays project: rear differential swap. a little stuck. LatentWagen Tri-State Area Forum 23 06-27-2005 01:11 AM
Swapping Differentials/Final Drive on a 2002 GX 2002GX Transmission (AT/MT) & Driveline 2 05-08-2005 09:44 PM
Limited slip viscous coupling rear differential swap into a '99 Impreza. powerlabs Subaru Conversions 11 04-25-2004 11:41 PM
Message Board Statistics All times are GMT -4. The time now is 05:22 AM.
