Old 04-28-2005, 06:55 PM   #1
Optimus Prime
Member#: 69847
2010 Evolution X
Default Will an EcuTek flash pass emissions in NY?
Will an EcuTek tune pass emissions (OBDII wise) in New York State?
Optimus Prime is offline   Reply With Quote
Old 04-29-2005, 06:20 AM   #2
methinkadoo
Member#: 37419
yes, most likely so.
methinkadoo is offline   Reply With Quote
Old 04-29-2005, 11:04 AM   #3
Optimus Prime
Member#: 69847
2010 Evolution X
The "most likely" part scares me, I need to know 100%.
Old 04-29-2005, 12:06 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
To pass in NY with the OBDII inspection, there must be no codes stored (not just a suppressed CEL), and all the readiness tests must be complete. This may involve not just the reflash but other mods as well, for instance if you have an electrical CEL fix it will interfere with the readiness tests while the mechanical fix will not.
I suggest you pose this question to whomever did your reflash. You can also find a local member with a scanner and check it yourself to see if it meets the conditions for inspection.
Old 04-29-2005, 12:13 PM   #5
Optimus Prime
Member#: 69847
2010 Evolution X
Thanks for the reply. Would the Computer Serial number effect the OBDII result (this is an 05 STi and I remember there was something about a serial number on it)?
Old 04-29-2005, 12:19 PM   #6
jim1969
Member#: 34877
2005 Legacy GT sedan
Another question is: does NYS check the CVN checksum? If it does then you'll fail because it changes as a result of the reflash whereas the CIN and VIN do not.
jim1969 is offline   Reply With Quote
Old 04-29-2005, 12:35 PM   #7
isis
Member#: 73283
05 CTS-V
03 Z1000
Call your tuner first.
and then call a local inspection station, one that you do not go to, and tell them your friend told you that it'd be ok, but you think he's wrong.
isis is offline   Reply With Quote
Old 04-29-2005, 01:06 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Also if you have an 05 it does not get scanned for the first two years. Those inspections will be safety only.
Will Invidia V2 DP pass emissions in NJ? MPEJ20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-13-2008 05:53 PM
where to get an ecutek flash in va,de,md? moorebl Mid Atlantic Impreza Club -- MAIC 1 11-15-2005 07:38 PM
Will APS 3" catless pass emissions in TX? fastseven Texas Impreza Club Forum -- TXIC 19 06-11-2005 12:00 AM
Any1 pass emission in NY? cool555 Tri-State Area Forum 6 01-21-2005 02:34 PM
Will a Stage 4 WRX pass emissions in PA? STR8OUT Tri-State Area Forum 11 05-07-2003 10:05 PM
