Old 04-28-2005, 07:16 PM   #1
UM-WRXer
Member#: 44623
Default Ecutek dyno tune
This might be a very common question but what is the average amount of time it takes to get a dyno tuned ecutek mapped for a stage 4 setup (td05-16g, 630cc inj, tmic, intake, catless exhaust) at about 17 psi?
I plan on either going to KTR performance in MA or XX tuning is CT. I think im leaning towards ktr since they have tuned uber amounts of WRX's and are cheaper per hour than XX....So would 2 hours of tuning be suffiicent for a street map? Would i possibley have enough time for a race map also? Thanks for the thoughts!
UM-WRXer is offline   Reply With Quote
Old 04-28-2005, 08:07 PM   #2
MikalsWRX
Member#: 40702
2002 Wagon stg 3.5
If everything goes smooth. But everycar is different. I wouldnt want a tuner to rush my car. I would rather just waite and have them take the time. My tuner told me 2 hours for my U-tech and 6 hours later they were done.
MikalsWRX is offline   Reply With Quote
Old 04-28-2005, 08:31 PM   #3
UM-WRXer
Member#: 44623
Yea i agree, i want my tuner to have ebough time to do it right. I just need to know how much money to go down there with. Any other expereinces from other people? 6 hours @ $200/hr can get pretty taxing.....
Old 04-29-2005, 12:05 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
mine took about 2 hours.... with www.pdxtuning.com
Jamie
www.subiegal.com
Old 04-29-2005, 12:27 AM   #5
XtianLA
Member#: 29958
03 WRX
Try to find a tuner that is good and will do an Ecutek at a flat rate, but that can guarantee at least a few hours on the dyno. A lot of tuners will say it will only take an hour and then do a quick 45min. tune. That's not a way to save money...it's a way to get a half-a**ed tune.
XtianLA is offline   Reply With Quote
Old 04-29-2005, 08:37 AM   #6
chrisfranklin
Member#: 59737
2004 sti
crappy subaru white
a good tuner who has lots of experience should be able to get you a close ballpark estimate based on their experience alone.
and then, should the tune require more tweaking, etc they should be able to stay close to the proximity of the original estimate even if that means cutting you a break on the extra time.
it would be unethical for a tuner to quote you a small estimate and then either give you a half assed quick tune, or bill you an exorbitant amount over the original quote.
within an hour or so would seem very acceptable. if they can't do that i would question their level of experience.
just my .02
chrisfranklin is offline   Reply With Quote
Old 04-29-2005, 10:41 AM   #7
UM-WRXer
Member#: 44623
Hey guys thanks a lot for all the responces. They are all appreciated
When emailing KTR about the amount of time it would take they said 2 hours. I think that is a good estimation since they have tuned many many (from the published dyno gallery on thier website) wrx's and sti's. I beleive thier experience would tell me that thier quote should be sufficient for what i need.
Now I just hope i dont run into any snags like an up pipe leak or problems with my modified injectors....which have been flow cleaned and flowtested with excellent results...
Old 04-29-2005, 01:28 PM   #8
beefyib123
Member#: 55811
I don't know anything about KTR(never heard of them) but make sure the shop is someone you can trust. i just had a VERY bad exp with my dyno tune. basically what the tuner did was tuned the car with my UTEC's temp correct ON?????? ***?
beefyib123 is offline   Reply With Quote
Old 04-29-2005, 01:45 PM   #9
tora
Member#: 5851
09 Forester XT
+ NA Miata
We charge for 4-6 hours for any custom tune. I would not expect to have it done in 2 hours with the mods you have. Are you getting it road tuned as well or just dyno tuned?
tora is offline   Reply With Quote
Old 04-29-2005, 02:42 PM   #10
kpmatt00
Member#: 23304
2002 JDM STI V8 SWAP
Sold!
I have an Ecutek from KTR, been there twice now. The intial tune took frmo abt 8-1:30, with a lot of tweaking and abt 30 full pulls. They charged me for two hours however, so that was a flat rate. It is def worth it, and KTR is very good in my opinion.
kpmatt00 is offline   Reply With Quote
Old 04-30-2005, 08:52 PM   #11
Porter
Member#: 486
2004 Forester XT
bug spattered
Your understanding of EcuTeK seems limited. If the tuner has any level of experience with the system and has a number of solid base maps developed, it should only take an hour or so to fine tune the setup for the particular mods on the car, especially if a decent dyno is being used with externally sampling wideband AFR.
Porter is offline   Reply With Quote
Ecutek dyno tuning Tea cups Commercial ECU Reflashes 18 09-07-2006 04:30 PM
One time EcuTek reflash with custom dyno tune offer PDXTuning North West Impreza Club Forum -- NWIC 3 10-13-2004 06:29 PM
Ecutek dyno tune results rexxturbo Engine Management & Tuning 2 10-29-2003 03:35 PM
Where to get a ECUtek Dyno tune around North Carolina?? trhoppe Engine Management & Tuning 2 08-02-2003 01:22 AM
Shiv's coming to Town (almost like Santa!!) for ECUTek Dyno tuning. WRBLUEWAGON Tri-State Area Forum 73 12-19-2002 03:46 PM
