Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 04-28-2005, 08:04 PM   #1
realwomble
Member#: 49305
2002 Stg.2 WRX Wagon
Default Oil analysis, 02 WRX, 7.5k M1 5-30.
http://theoildrop.server101.com/ubb/...c;f=3;t=002525
It's pretty bad. Suggestions appreciated.
realwomble is offline   Reply With Quote
Old 04-28-2005, 08:28 PM   #2
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Its not that bad and its your first fully synthetic oil. You may have picked up some residual stuff that was hanging out in the engine. Was the oil changed when it was warm or hot? Has it been changed that way in the past? If the dealer changed it, maybe not. Cars tend to sit in the lot for awhile and cool off before they get around to working on them. I think an analysis after your next oil change will tell you a lot more.
OneOBS is offline   Reply With Quote
Old 04-28-2005, 08:37 PM   #3
realwomble
Member#: 49305
Hmm.
When I put that oil in (first change I did myself), the car was cold.
When I changed it out this time, it was hot (shoots out faster / further that way... as I discovered )
Maybe I'll take some oil out for analysis after 4k after re-checking air filter and IC hoses.
Thanks.
Old 04-28-2005, 08:58 PM   #4
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Hot oil holds more contaminents in suspension. That may be your answer right there.
Old 04-28-2005, 09:32 PM   #5
rexaroo
Member#: 35732
2002 WRX Wagon
My personal feeling is 7500 miles even with synthetic is too long to go with a turbo engine. I'd stick to no more than 4K to be on the safe side. 6K if you really baby it and do a lot of hwy miles. Also, the Mobil 10W30 shows better oil analysis results over on BITOG.com than the 5W30.
rexaroo is offline   Reply With Quote
Old 04-29-2005, 02:52 AM   #6
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
I think the short 8 mile trips are the reason for the "relatively" bad results compared to other UOA reports. The other WRXes with better 7500 mile UOA reports all have longer commutes. With 8 mile short trips maybe 5000 mile oil change interval is more suitable, if you want to get reports as good as others. Nothing really wrong with your report though, just not as good as others.
Gunner is offline   Reply With Quote
Old 04-29-2005, 01:33 PM   #7
bluesubie
Member#: 767
04 FXT
It's probably too long on M1 5W30.
I posted some of my UOA links for comparison over on BITOG since I take short trips weekdays as well. My Si is probably high due to the Amsoil air filter (and wearing in) and an OEM filter went in at the last OC.
-Dennis
Old 04-29-2005, 02:52 PM   #8
realwomble
Member#: 49305
Did you have high wear metals as well?
(edit)
Just checked them out. Your Si is comparable to mine, but your lead is still very low. My lead (bearings?) is sky high....
Old 04-29-2005, 02:59 PM   #9
realwomble
Member#: 49305
Comments from TooSlick over at BITOG below.
Any suggestions where to check for vaccum leaks, other than IC hoses?
The Cr and Al levels are fine and there is no nickel present which would indicate valve stem wear. I'd say you are ingesting silicon particles directly into the crankcase through a vacuum leak, and some of these are larger than your bearing clearances. This is the cause of your elevated valve train and bearing wear.
A wear rate for Fe of > 3 ppm/1000 miles is abnormal for any 2.0L engine that uses a timing belt and not a lubricated chain. Bearing wear is also at least twice as high as it should be....
I'd suggest running a 5w-40/10w-40 with a HT/HS viscosity of at least 4.0 Cp, until you get this problem resolved. The thicker oil will keep you from getting into a boundary lubrication situation so often.
When you have high levels of abrasives (dirt/soot) present you want to avoid having to depend on AW additives. The integrity of these very thin, AW films will be severely degraded by hard abrasive particles....
Old 04-30-2005, 03:07 PM   #10
esteve
Member#: 28716
2006 STI
How critical is it to sample the "middle" part of the drain? I know the reasoning behind it, but I'm curious how much taking the first or last oil out of the engine will affect the readings.
esteve is offline   Reply With Quote
Oil Analysis - 2005 WRX 113,000 miles Ahersh Service & Maintenance 17 03-18-2008 02:37 PM
Oil analysis on German Castrol Syntec 0W30, 5,930 miles, FXT bluesubie Service & Maintenance 8 03-26-2005 10:06 AM
'04 STi (stock) engine oil analysis report at 7,323 miles. lstepnio Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 03-14-2004 11:59 PM
02 Wrx, $16.5k E. Nick Private Vehicle 'For Sale' Classifieds 5 10-29-2003 05:43 PM
Oil analysis on WRX /M1 10W30 bluesubie Transmission (AT/MT) & Driveline 1 08-13-2003 09:04 AM
