Old 04-28-2005, 09:05 PM   #1
84SubaruDL
Member#: 42179
SON! F 22's i roll
on 33" 12 fity SON!!!
Default accessport and CEL fix?
should i remove my resistor (Cell Fix) from my 02 sensor if im running a Cobb Stg 2?
84SubaruDL is offline   Reply With Quote
Old 04-29-2005, 02:44 AM   #2
Call_me_Tom
Member#: 60972
Good question I've never thought about that one. I believe that Stage 2 removes both the Up Pipe CEL and I know for sure the Down pipe CEL. You could leave it in and it wouldn't hurt any thing or you could take 5 min and test it out. If it throws a CEL use the AP and clear your DTC and then throw back in the resistor.
Call_me_Tom is offline   Reply With Quote
Old 05-02-2005, 11:53 PM   #3
shinsain
Member#: 51745
LIKE A
BOSS
According to map notes for the Stg 2 V1.22 and Stg. 1 V1.20 it is one of the CEL's that is deleted already, so you shouldn't have any problems:
CEL Codes Defeated [WHEN USING AS BASE MAP]
(** means new to latest revision):
P0037 - Rear O2 Sensor Heater Control Circuit Low **
P0038 - Rear 02 Sensor Heater Control Circuit High **
P0137 - Rear O2 Sensor Low Voltage **
P0138 - Rear O2 Sensor High Voltage **
P0139 - Rear O2 Sensor Circuit Slow Response **
P0420 - Catalyst System Efficiency Below Threshold
P0545 - Exhaust Gas Temperature Sensor Circuit Low
P0546 - Exhaust Gas Temperature Sensor Circuit High
P1301 - Misfire Detected (High Temperature Exhaust Gas) **
P1312 - Exhaust Gas Temperature Sensor Malfunction **
P1544 - Exhaust Gas Temperature Too High **
Aaron
shinsain is offline   Reply With Quote
Old 05-03-2005, 12:11 PM   #4
Rob420
Member#: 39703
. 2007 GREY STI
02 WRX & 08 STI- RETIRED
I just left my CEL FIX installed when I moved to AP STG 2
Rob420 is offline   Reply With Quote
Have Accessport...need cel fix? TQuintin Engine Management & Tuning 3 07-02-2004 09:49 PM
Perrin Uppipe with studs and CEL fix jroberts Private 'For Sale' Classifieds 7 01-13-2004 10:43 PM
Invidia downpipe and CEL fix jdmhebek9 Private 'For Sale' Classifieds 4 08-28-2003 11:51 PM
Guys running a catless down-pipe and cel fix.Any probs with OBDII testing? Camperguy New England Impreza Club Forum -- NESIC 7 08-11-2003 07:51 PM
For Sale, HKS Carbin/TI cat back with Helix Down pipe and CEL fix. $800.00installed!! WRBLUEWAGON Tri-State Area Forum 8 01-28-2003 01:33 PM
