Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Old 04-29-2005, 09:36 AM   #1
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Question Why so rich (UTEC)?
Iím running the default Stage-II MAP on my UTEC and appear to be running extremely rich. From the logs it appears to be running rich throughout the entire boost curve which as a result is making the car run like crap. It actually runs better (AFR) on the stock MAP and has more performance then the Stage-II MAP.
Iím running up/down pipes, 3Ē TBE, TMIC, BOV, and a Perrin intake. Stock turbo, stock injectors, 93 octane.
My question, why in the hell is the Stage-II MAP running so rich and how do I adjust it accordingly?
UTEC (default) Stage-II:
Code:
RPM  TPS  MAP  MLP IGN  AFR  KNOCK
2125 051  -3.4  00 +22.5 15.0 00000
2198 097  -1.8  10 +21.5 13.2 00000    <-Start 2nd Gear Pull
2295 097  -0.4  10 +20.0 12.7 00000
2350 097  +1.1  10 +18.5 13.0 00000
2442 097  +1.9  20 +17.6 12.5 00000
2568 097  +2.7  20 +17.0 12.4 00000
2664 097  +3.7  30 +17.0 13.0 00000
2770 097  +4.7  40 +17.0 rich 00000
2901 097  +6.2  40 +17.0 rich 00000
3035 097  +7.8  50 +16.0 rich 00000
3205 097  +9.6  60 +16.0 rich 00000
3397 097 +11.3  70 +15.0 rich 00000
3599 097 +12.7  80 +14.0 rich 00000
3745 097 +13.7  80 +14.0 rich 00000
3875 096 +13.9  80 +15.2 rich 00000
4070 097 +14.3  80 +16.1 rich 00000
4230 097 +14.1  80 +16.9 rich 00000
4374 097 +13.9  70 +17.0 rich 00000
4510 097 +13.5  70 +17.8 rich 00000
4694 096 +13.1  70 +18.4 rich 00000
4887 097 +13.1  70 +19.8 rich 00000
5035 096 +13.5  80 +21.0 rich 00000
5184 097 +13.1  70 +21.0 rich 00000
5324 095 +13.5  70 +21.0 rich 00000
5491 097 +13.7  80 +21.0 rich 00000
5747 096 +13.1  70 +21.0 rich 00000
5797 097 +13.3  70 +21.3 rich 00000
6150 096 +12.7  70 +21.8 rich 00000   <-Stop 2nd Gear Pull
5868 021 +11.5  00 ECU.  rich 00000
5555 000  +6.2  00 ECU.  rich 00000            shifting
5175 000  +0.2  00 ECU.  23.2 00000            shifting
4219 055  -4.3  10 +20.7 24.2 00000
4301 097  -5.9  10 +21.0 12.2 00000   <-Start 3rd Gear Pull
4317 097  -1.2  40 +20.0 rich 00000
4385 097  +5.5  70 +17.0 rich 00000
4516 096 +10.2  80 +17.2 rich 00000
4655 096 +12.9  70 +17.8 rich 00000
4721 097 +14.1  70 +18.2 rich 00000
4755 096 +13.5  80 +18.8 rich 00000
4852 097 +13.9  80 +19.6 rich 00000
4901 097 +14.3  80 +20.0 rich 00000
5012 096 +14.1  80 +20.6 rich 00000
5104 096 +13.7  70 +21.0 rich 00000
5089 096 +13.1  70 +21.0 rich 00000
5175 096 +12.3  70 +21.0 rich 00000
5274 097 +12.5  70 +21.0 rich 00000
5291 097 +12.5  70 +21.0 rich 00000
5402 096 +12.5  70 +21.0 rich 00000
5464 096 +12.3  70 +21.0 rich 00000
5500 096 +12.1  60 +22.0 rich 00000
5602 097 +12.5  70 +21.0 rich 00000
5640 097 +12.3  70 +21.0 rich 00000    <-Stop 3rd Gear Pull
5437 020 +12.3  00 ECU.  rich 00000
5299 000  +7.0  00 ECU.  rich 00000
4952 000  +1.1  00 ECU.  20.4 00000
4559 000  -4.9  00 ECU.  lean 00000
3866 000 -10.0  00 ECU.  24.2 00000
3912 000 -10.4  00 ECU.  24.2 00000
3903 000 -10.8  00 ECU.  24.5 00000
Stock MAP:
Code:
1770 010  -2.0  00 ECU.  13.9 00000
1847 010  -2.0  00 ECU.  13.8 00000
1915 079  -1.6  10 ECU.  13.9 00000
2021 098  -0.8  10 ECU.  12.8 00000     <-Start 2nd Gear Pull
2116 098  +0.2  10 ECU.  12.9 00000
2225 098  +1.3  20 ECU.  12.6 00000
2340 097  +1.9  20 ECU.  12.8 00000
2443 097  +2.5  20 ECU.  12.6 00000
2558 097  +3.1  20 ECU.  12.7 00000
2681 097  +3.9  30 ECU.  12.6 00000
2824 097  +4.5  30 ECU.  12.4 00000
2981 097  +5.7  40 ECU.  rich 00000
3106 097  +7.4  50 ECU.  rich 00000
3316 097  +9.8  70 ECU.  rich 00000
3483 097 +11.9  80 ECU.  rich 00000
3658 097 +13.7  80 ECU.  rich 00000
3840 097 +14.7  80 ECU.  rich 00000
4084 097 +15.1  80 ECU.  rich 00000
4273 097 +14.9  80 ECU.  rich 00000
4415 096 +14.3  70 ECU.  rich 00000
4636 097 +14.3  80 ECU.  rich 00000
4816 097 +13.7  80 ECU.  rich 00000
4982 097 +14.1  80 ECU.  rich 00000
5192 096 +13.9  70 ECU.  rich 00000
5437 097 +13.7  70 ECU.  rich 00000
5546 096 +13.5  70 ECU.  rich 00000
5757 088 +12.5  70 ECU.  rich 00000    <-Stop 2nd Gear Pull
5889 028 +12.5  60 ECU.  rich 00000
5527 000  +6.8  00 ECU.  13.8 00000   	      shifting
5192 000  +0.8  00 ECU.  lean 00000 	      shifting
4504 027  -4.0  10 ECU.  24.5 00000
4257 098  -6.5  10 ECU.  23.7 00000   <-Start 3rd Gear Pull
4306 097  -2.4  30 ECU.  rich 00000
4380 097  +3.3  50 ECU.  rich 00000
4397 096  +9.0  70 ECU.  rich 00000
4522 097 +11.5  70 ECU.  rich 00000
4604 096 +12.9  70 ECU.  rich 00000
4721 097 +13.1  70 ECU.  rich 00000
4775 097 +13.3  80 ECU.  rich 00000
4859 097 +14.3  80 ECU.  rich 00000
5192 097 +14.7  80 ECU.  rich 00000
5136 096 +15.1  80 ECU.  rich 00000
5224 097 +15.7  90 ECU.  rich 00000
5241 096 +14.9  80 ECU.  rich 00000
5367 097 +14.7  70 ECU.  rich 00000   <-Stop 3rd Gear Pull
5464 027 +14.1  70 ECU.  rich 00000
5341 000  +7.8  00 ECU.  rich 00000
4930 000  +1.9  00 ECU.  lean 00000
4528 000  -4.3  00 ECU.  lean 00000
3753 000 -10.0  00 ECU.  24.2 00000
3699 000 -10.2  00 ECU.  24.2 00000
Anyone with suggestions please chime in...
xcntrk75 is offline   Reply With Quote
Old 04-29-2005, 09:42 AM   #2
MMBOOST
Member#: 24140
02 Impreza WRX
http://www.logmapper.com
All the basemaps are quite rich. TXS does this on purpose, for safety's sake. Its your job to work them out properly. However, as you can see, with your stock wideband O2 sensor you're not really able to get a good look at the AFRs (it just says "rich"). You're unable to see anything below ~12.0:1. So to be safe you might want to run 11.0:1 or richer AFRs in higher loads, but you'll never be sure that things are safe until you get a more robust wideband O2 sensor.
Also, when you log, its good practice to you Log #1 (hitting the '1' key to log), instead of the smaller log you're using.
MMBOOST is offline   Reply With Quote
Old 04-29-2005, 09:45 AM   #3
Davenow
Member#: 23676
you WANT IT TO SAY RICH. If you see anything other than "rich" in that space when under any kind of decent boost, you are too lean. Its because you dont have a wideband setup, the factory o2 sensor only reads a certain amount up and down, beyond that it will just say "rich"
Suffice it to say, at 8+lbs of boost, if it doesnt say "rich", It is dangerously lean.
You CAN adjust it leaner, but only keep doing it until it JUST starts reading something other than rich, then put a little fuel back at a time until it says rich again.
Really if you want to tune it, you need a wideband, because fuel tuning with the UTEC without a wideband can be done, but it is a DANGEROUS game if you dont know what you are doing 100%.
Old 04-29-2005, 11:37 AM   #4
MMBOOST
Member#: 24140
02 Impreza WRX
Originally Posted by Davenow
etc...
etc...
Hmmm, thisis terrible advice. You really have no idea what's going on when the UTEC reports "rich". All you know is that your AFRs are 12.0:1 or below. Also, despite having a crappy range, the further the stock WB sensor gets below 14.7:1 the less accurate it is. I woul d not lean out ANYTHING util you have a wideband. Davenow, and myself, have no idea what kind of fuel you are running, or what mechanical issues you might have on your car, etc.
I began tuning the low end before I got my WB and did a bit of tweaking on the high end. When I got my WB finally I found out I was running around 11.8:1 at 17PSI on Cali 91 piss. No wonder I was getting knock now and again :-/ I just kept taking out timing which, of course was just raising EGTs and probabaly making matters worse. I was very lucky that I didn't damage my engine.
Tuning loadsites without being able to see their actual AFR is asking for trouble. An EGT gauge can be helpful, but not very good for eeking out performance... so why bother tuning these days w/o a WB anyhow? If you were tuning in response to a recent log would you tune loadsites that you didn't hit and have no info for?
jason
Old 04-29-2005, 06:24 PM   #5
AaronWRX
Member#: 7194
2011 997.2 Turbo
Wirelessly posted (blackberry: BlackBerry6280/3.7.1 UP.Link/1.1)
I'm with jason. Mucking with fuel without a wideband isn't ideal.
Imo, utec useres have two options,
#1) self-road-tune AFTER getting setup with a boost, egt, and wb02 gauge +lot's of reading and lots of logging sessions with your car
#2) get it dyno tuned.
AaronWRX is offline   Reply With Quote
so rich fuel out the exhaust SethV Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 10-06-2008 12:17 AM
HELP! car reassembled now running so rich it wont even idle sinnerlv Engine Management & Tuning 10 09-15-2005 11:58 PM
I'm going to be so RICH! FederalAuditor Engine Management & Tuning 18 09-29-2004 04:50 PM
Why am I running so rich? Dorkfish Normally Aspirated Powertrain 4 05-22-2004 11:19 PM
Why am I running so rich?? karl_hungus Normally Aspirated Powertrain 11 03-24-2003 09:00 AM
