Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 04-29-2005, 02:19 PM   #1
fuss310
Member#: 70563
Default Taking UTEC off
I am going to be taking off my UTEC soon and was wondering If I am going to be needing anything that was taken off while the utec was orginally installed. I am going to be changing over to ECUTEK.
Thanks!
fuss310 is offline   Reply With Quote
Old 04-29-2005, 02:36 PM   #2
Optimus Prime
Member#: 69847
2010 Evolution X
Can't help, but what made you go to EcuTek?
Optimus Prime is offline   Reply With Quote
Old 04-29-2005, 02:44 PM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
You will want to remove the ABC also, but that's it.
mbiker97 is offline   Reply With Quote
Old 04-29-2005, 04:11 PM   #4
fuss310
Member#: 70563
Optimus Prime
For what I am looking to do, EcuTek is best for ME. When I first was looking
around for EM, my then tuner advised me to go UTEC since at that time I just had up and downpipe and tbe. I know I was still going to be upgrading turbo, air charge cooler and so on, so I decided that as long as my tuner could make it work then it would be ok. At first it was cool I was happy and it makes good power, at times knock even with the "safe" bad tank of gas map. I go back and fourth to the guy who installed, he pretty much told me its better if you learn how to tune it yourself. I responded telling him that before I got it, I was clear that I was not interested in doing it myself (at that time he was not doing EcuTek)
Anyways to make a long story short I went elsewhere and that place assures me that he will take care of me with a reflash.
Thanks also Mbiker.
Old 04-29-2005, 04:40 PM   #5
XSTransAm
Member#: 17789
2006 Yamaha R6
bikes are faster ;)
the only difference between the ecutek and the utec that your going to have is when it knocks with the ecutek you wont know...
if you turn off the knock control on the utec then you will have just about exactly what an ecutek is.
XSTransAm is offline   Reply With Quote
Old 04-29-2005, 06:01 PM   #6
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Wrong. True there is no idicator showing you that it knocks, but ECUtek (since it really is just the factory ECU) listens for knock and adjusts timing accordingly. The Utec isn't great yet. It will be soon, but not currently.
Old 04-29-2005, 06:23 PM   #7
XSTransAm
Member#: 17789
2006 Yamaha R6
bikes are faster ;)
and we all know how well the stock ecu adjusts for knock
Old 04-29-2005, 08:09 PM   #8
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
I've not seen a single car blow up using ECUtek yet, the same cannot be said for some Utec users (consider both to be fully dyno tuned).
Old 04-29-2005, 08:31 PM   #9
fuss310
Member#: 70563
[quote=XSTransAm]the only difference between the ecutek and the utec that your going to have is when it knocks with the ecutek you wont know...
True that, but I do have a knock link installed.
Old 04-29-2005, 08:48 PM   #10
XSTransAm
Member#: 17789
2006 Yamaha R6
bikes are faster ;)
now thats just an unfair statement, the blown up cars you are talking about have and always will be user error. its just as easy to blow up a car with a ecutek. the reason it dosent happen as often (and im positive it has happened) is because ecutek dosent give the end user the ABILITY to adjust their product. (and this is the reason they dont)
the bottem line is, fuel timing and boost, no matter what the tool used to adjust them are still just that, fuel timing and boost.
Old 04-29-2005, 09:29 PM   #11
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
There is a lot more that can be adjusted using an ecutek as opposed to a utec. Hopefully some time in May a true user tune version of the Ecutek willl be available. Either way I would keep the utec until this version is out. If you want some else to tune it you can still get it done but if you want to make changes then you have that option as well.
LiquidForce is offline   Reply With Quote
Old 04-29-2005, 10:25 PM   #12
fuss310
Member#: 70563
Will look into that Liquid. Thanks.
Old 05-01-2005, 10:02 PM   #13
Optimus Prime
Member#: 69847
2010 Evolution X
Disagree. UTEC is a piggyback system interfacing with the stock ECU, whereas EcuTek reprograms the stock ECU and let's it calculate the rest. If this setup were on an IS300, the UTEC would work for about a week before the IS300s ECU would starteto compensate for the UTEC and cause a lot of problems (yes, IS300 ECUs are that sucky/smart). I'd rather have ONE system/processor handling my engine instead of using an external device that interfaces/interferes with a stock computer to make it work right.
I would however like a MAFless EcuTek.
But back on subject, if I were the original poster, I would get an EcuTek tune, and leave the UTEC in there so you could use a race gas map...and if you ever wanted to go MAFless.
Old 05-02-2005, 10:47 AM   #14
Full Throttle
Vendor
Member#: 66143
A mafless option will be a reality soon for everyone
Mike
Full Throttle is offline   Reply With Quote
Old 05-02-2005, 10:59 AM   #15
lowblow
Member#: 56902
2009 VW Jetta SE
That is why you get a Hydra or AEM EMS...
lowblow is offline   Reply With Quote
Old 05-02-2005, 11:04 AM   #16
TheMadScientist
Member#: 23717
2005 Big red
Mike
Are you saying you are going to release a MAFT for the subaru?
Sorry for the hijack.
TMS
TheMadScientist is offline   Reply With Quote
Old 05-02-2005, 11:31 AM   #17
happasaiyan
Member#: 37731
i dont think you really understand how the utec works.
assuming OLF enabled-
the UTEC fires the injectors. not the stock ecu. the UTEC takes the stock input and either modifies it (idle/below TPS x-over), or just ignores the stock signal and fires it itself (OLF).
the UTEC has its own ignition drivers. the UTEC takes the stock input and either leaves it unchanged (idle/below TPS x-over), or just ignored the stock signal and sends the signal itself (over TPS x-over, or modified 0 column).
there are many benefits to having everything central (ie- a reflash), but dont underestimate the UTECs power and flexibility. unless in the case of a bug in the software (or a physical limitation), an engine blown up by a UTEC was/is/always has been a tuning error.
your statements are true in regards to an SAFC or an e-manage, however. the utec...is a different beast.
happasaiyan is offline   Reply With Quote
Old 05-02-2005, 11:36 AM   #18
happasaiyan
Member#: 37731
TMS
http://forums.nasioc.com/forums/show...66#post9671866
i dont know if you saw this, TMS...but its all the benefits of the MAF, with most of the benefits of MAP...
Old 05-02-2005, 12:20 PM   #19
TheMadScientist
Member#: 23717
2005 Big red
I had not seen that yet. I have seen some of the DSM guys do that. First subaru that I have seen trying a blow through.
TMS
Old 05-02-2005, 01:40 PM   #20
Optimus Prime
Member#: 69847
2010 Evolution X
No, cause then you lose OBDII and can not pass emissions.
Old 05-02-2005, 01:42 PM   #21
Optimus Prime
Member#: 69847
2010 Evolution X
I wasn't aware that the UTEC was actually directly connected in that way. Sorry about that. I do think though that if you have UTEC already and you want EcuTek, keeping both is a good idea.
Now whats this about the MAFless MAF Mr. FullThrottle!?
Old 05-02-2005, 01:55 PM   #22
lowblow
Member#: 56902
2009 VW Jetta SE
There is a fix for that, but I can't find where I read the info about maintaining a signal at the OBDII port just for emissions purposes...I'll see if I can find it.
Old 08-17-2005, 10:45 AM   #23
forgedSTi
Member#: 89210
2012 Impreza WRX STi
Pearl White
you can't find it because it doesn't exist. The fix is to put your stock ecu back in for the emissions test.
forgedSTi is offline   Reply With Quote
Old 08-17-2005, 03:36 PM   #24
titsataki
Member#: 4402
This was my idea until I tried to tune my ECUTEC while I had my UTEC on Map 0. I thought it was a passthrough position but it is not so. Read on.
http://forums.nasioc.com/forums/showthread.php?t=821552
Cheers
Nick
titsataki is offline   Reply With Quote
Old 08-17-2005, 07:53 PM   #25
Focus4
Member#: 20107
2004 STi
If you still have it, throw the little plastic ECU cover back on. I forgot to put mine back on, and haven't noticed any ill-effects, but someone said they had drippage on theirs during the hot summer months... don't know how that got there but if you have it you might as well throw it back on...
give them 2 $20's and you'll pass
Focus4 is offline   Reply With Quote
Me+ takeing my UTEC off= 7 codes bluimpreza00 Engine Management & Tuning 3 11-07-2003 08:42 AM
Hakkinen to take year off... WRXSTI? Motorsports 3 11-01-2001 07:31 PM
Suzuki Takes Wraps Off WRC Contender Dirt Man Motorsports 6 10-27-2001 11:52 PM
How do I take it off? ashtaron14 Vancouver Impreza Club Forum -- VIC 1 06-09-2001 11:22 PM
Warning: don't take parts off of crashed scoobies! delectron Bay Area Impreza Club Forum -- BAIC 17 10-18-2000 05:06 AM
