Old 04-29-2005, 04:04 PM   #1
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
Default Ring and Pinion Swap
Are there any special tools needed for changing the ring and pinion in the R160? Thanks.
spoolinsuby is offline   Reply With Quote
Old 04-29-2005, 04:09 PM   #2
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
No special tools needed.
wrx plus is offline   Reply With Quote
Old 04-30-2005, 12:48 AM   #3
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
Don't you need shims and stuff? And the stuff to set bearing preload? And a press? Maybe not.
Al_Smokemcrack is offline   Reply With Quote
Old 04-30-2005, 07:57 AM   #4
wrx plus
Member#: 42253
2003 RWD WRX
When I broke my pinion, I didn't need any of that. I replaced both the ring and the pinion.
Old 04-30-2005, 10:46 AM   #5
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
At least chec to make sure the bearing pre-load and backlash adjustments are correct. The biggest variation in tolerances comes from the diff. carriers. If you were changing out a carrier you would DEFINATELY want to re-shim the whole thing. Changing a ring and pinion will alter stuff slightly. If you are in the middle of the tolerances before you changed anything you would be fine. But if you were on one of the outer ends of the tolerances the new ring and pinion may have pushed you out.
no-coast-punk is offline   Reply With Quote
Old 04-30-2005, 02:48 PM   #6
02Toyowrx
Member#: 56520
where can i get a good deal on a complete 4.44 conversion front and back?
02Toyowrx is offline   Reply With Quote
Old 05-01-2005, 07:35 PM   #7
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
how do I check the tolerances?
Old 05-01-2005, 08:24 PM   #8
ashumo
Member#: 51318
89 SVX Syncro
2nd this question as im going to 3.90
ashumo is offline   Reply With Quote
Old 05-02-2005, 05:51 PM   #9
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
bump for answer
Old 05-03-2005, 05:24 AM   #10
duncangrant
Member#: 30009
98 Legacy BG5B
Black twin-turbo
Rtfm.
duncangrant is offline   Reply With Quote
Old 05-03-2005, 02:50 PM   #11
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
what the hell is rtfm??
Old 05-03-2005, 03:17 PM   #12
silentbob343
Member#: 57307
Read the F**ing Manual=RTFM
4.44 F/R can be purchased from Rallispec in NJ or at least they can get them.
What Subaru manual would specify how to do a ring/pinion swap? I would be interested in purchasing it.
silentbob343 is offline   Reply With Quote
Old 05-03-2005, 03:19 PM   #13
duncangrant
Member#: 30009
98 Legacy BG5B
Black twin-turbo
Read The Fiicking Manual!
Sorry if that sounds unhelpful, but if you are going to do it right you need to have the workshop manual (pdfs on various sites) and read it. The USDM sti pdfs are pretty good but I forget where they are hosted.
Old 05-03-2005, 07:42 PM   #14
ashumo
Member#: 51318
89 SVX Syncro
good point...
v
Old 05-03-2005, 07:47 PM   #15
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
anyways...
MK19_ is offline   Reply With Quote
Old 05-04-2005, 01:35 PM   #16
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
Originally Posted by MustangKilla
anyways...
What did you say I got here to late
Old 05-05-2005, 12:04 AM   #17
ashumo
Member#: 51318
89 SVX Syncro
didnt you get the pm i sent you
Old 05-05-2005, 05:33 AM   #18
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
i got the pm, i pmed you back. is that what he posted??
Old 05-05-2005, 03:56 PM   #19
ashumo
Member#: 51318
89 SVX Syncro
no i posted it and didnt want the guys site to get ate up.
Old 06-05-2005, 11:55 PM   #20
gpatmac
Member#: 18446
2002 WRX wagon
psm
This isn't the guy you're talking about. It's some Russian website, but the page is exactly the same.
[Sorry, no posting of manuals is allowed on the forums.]
gpatmac is offline   Reply With Quote
Typical cost of a Ring and pinion swap? scooby-stu Transmission (AT/MT) & Driveline 1 03-06-2006 10:29 PM
Rear diff ring and pinion swap... Does it matter if its locking or not? FederalAuditor Transmission (AT/MT) & Driveline 1 02-09-2005 04:09 PM
ring and pinion swap for 92' legacy Turbo swiggy Subaru Conversions 3 02-07-2005 09:20 PM
Ring and pinion swap ebeck Transmission (AT/MT) & Driveline 1 04-12-2004 09:46 PM
Ring and Pinion swap - Do it yourself? fragment Transmission (AT/MT) & Driveline 4 03-22-2004 06:19 AM
