Old 04-30-2005, 12:52 AM   #1
wildfire
Member#: 80471
95 Impreza L AWD
Green Poly
Impreza GC8 1.8 to 2.2 (ej22) Swap
95 L 1.8 to 95 2.2 swap in progress!
Lets start with everything is going great. 1.8 Broken down to block. 2.2 has intake manifold all wired up, only one wire that didn't hook up (gray right under throttle body on 2.2 block). It connected to the engine wire harness on the 2.2 manifold. Speaking of Intake compareing. The diffrence is large. But not anything to halt this swap ;=] mainly, the main body before the runners split is larger.
The runners on the 1.8 are smother on the inside. The only diffrence I should see is in throttle responce. The upper end should be better on the 1.8 manifold do to it's better flow design. In reality the 2.2's intake manifold has more air in the body so when you stomp it the engine can gobble the air up with out having to injest through the air intake/throttle body. So, more air + fuel = better combution right? Man, I think everyone gets it. Tired, Have pic's! postem tomarrow ( "cleaned" pc desk off can't find usb for the camera ;=(), late, more info tomarrow, going great though Oh, yeah. Need info on the injectors any help will do. I'm going to swap them if no one has anything to say. more fuel lbs on 2.2? flow rate on 1.8 & 2.2??
Okay must sleep, I know I'm going to be dreaming about all this techno engine stuff all night! just look at my rambles already.
Lots more comming tomarrow,
~Wildfire
wildfire is offline   Reply With Quote
Old 04-30-2005, 04:07 AM   #2
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
so, whats you question?
-Eli
squirrelmasta is offline   Reply With Quote
Old 04-30-2005, 11:50 AM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Wildfire,
Actually the 1.8l manifold flows substantially less than the 2.2l I see guys talk all the time about the runner shape, etc., but that just doesn't make up for the fact that the inner diameter of the runners themselve are substantially smaller. The 2.2 manifold will flow more air. Measure the mating point where the manifold meets the heads. IIRC, it is at least 1/8"...
Old 05-01-2005, 03:25 AM   #4
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
my bro did the same excat swap of parts good choice nice power upage
99subi is offline   Reply With Quote
Old 05-01-2005, 03:25 AM   #5
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
whoops
Old 05-02-2005, 08:57 PM   #6
josepepe
Member#: 86342
Subaru Stars
what up people i just got my ej22 today and already have it in the car. (93 impreza wagon) how ever the exaust pipes were nat the same i had to cut them in order to fit them on the new motor. i will problably have it running tomarrow if i dont run into any other problem.
i will have u guys updated
josepepe is offline   Reply With Quote
1.8 to a 2.2 swap? notasubyguy Normally Aspirated Powertrain 26 01-31-2009 11:57 PM
95 1.8 to 98 2.2 swap jahwarrior007 Subaru Conversions 2 10-24-2008 08:34 PM
1.8 to rebuilt 2.2 drewdogg Subaru Conversions 34 07-11-2005 10:41 PM
Quick questions for those that have swapped from a 1.8 to a 2.5. EcksJay Subaru Conversions 16 05-06-2005 05:47 AM
1.8 to STi 2.0 swap... need some help. wagman01 General Forum Archive 5 02-21-2001 09:57 PM
