Old 04-30-2005, 01:04 AM   #1
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
Default utec launch controll? what setting 1 or 2?
so i put in the launch controll/map selector and i went into the utec to turn it on and to set the launch controll and what not and it says i have to pic setting 1 or setting 2? what one should i put it on is there any differance?
trbowrx is offline   Reply With Quote
Old 04-30-2005, 01:44 AM   #2
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
You want Injector cut (INJ), not Ignition cut (IGN), unless you have Nitrous installed.
serendipity is offline   Reply With Quote
Old 04-30-2005, 05:08 PM   #3
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
ok thanks i will do that
Old 05-01-2005, 11:27 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....and make sure that you have the $$$$ saved to fix whatever breaks when you use it.....'cuz you WILL break something....hopefully just the clutch, more likely the tranny....and maybe the engine will let go, too......BEWARE.
Old 05-02-2005, 02:08 AM   #5
dl337j00
Member#: 58049
1990 Skyline GTR
Gunmetal Grey
how will it break the clutch... i would imagine the launch control to help reduce wear on the clutch...
dl337j00 is offline   Reply With Quote
Old 05-02-2005, 08:48 AM   #6
beefyib123
Member#: 55811
if you are smart you will SLLLLLLIIIIIIPPPPP the clutch to save the tranny. If you dump the clutch you will QUICKLY be looking for an tranny parts. Unless you are running heavy mods (a Dog box to start with) you shouldn't be using launch control.
beefyib123 is offline   Reply With Quote
Old 05-02-2005, 09:14 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
...if you don't understand this, and it is apparent you do not.......DON'T.
It would be real easy to destroy the drivetrain of your car, and stand there with a stupid look on your face wondering what the hell just happened.....
Old 05-02-2005, 09:45 AM   #8
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Also keep in mind that Launch Control can be used for more than damaging-hard launches. My favorite use of this feature is the super smooth high-rev shifting capabilities. I have my LC rev set at 4,500k and you never have to lift your foot off the gas on high-rev shifts and it’s actually smoother then fully releasing the throttle…
I dig it…
xcntrk75 is offline   Reply With Quote
Old 05-02-2005, 10:06 AM   #9
pezman04wrx
Member#: 66558
^^^ Cool ... Flat foot shifting with a rev limiter ... Good call ...
pezman04wrx is offline   Reply With Quote
Old 05-02-2005, 10:09 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
....ya just gotta learn how to actually DRIVE, that's all
Old 05-02-2005, 10:12 AM   #11
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
I can't find that anywhere in my TXS UTEC manual......could you tell me where I could find it?
Does Kartboy make an add-on module for that?
BadTrip is offline   Reply With Quote
Old 05-02-2005, 10:33 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
flat foot shifting is great until you get into someone else's car and forget they don't have it!
seriously though i use it at least once a day. great fun.
Old 05-02-2005, 12:16 PM   #13
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I wouldn't use launch control on '02 motors. Shim over buckets...
cdvma is offline   Reply With Quote
Old 05-02-2005, 12:43 PM   #14
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
chris, issues with the drivetrain are invariably (at least all the reports i've seen) caused by using ignition cut. the ultra-rich unburnt air fuel mixture ends up in the hot exhaust manifold, which lights it off, causing a huge afterfire. the pressure wave from this afterfire literally pushes the exhaust valves open, causing them to spit their shims. it's all downhill from there.
i've been injector cutting for about a year. no issues.
one thing to keep in mind... holding full boost while stopped puts an ENORMOUS heatload in the intercooler, and with no airflow the core temp rises precipitously.
jm2c
ken
Old 05-02-2005, 06:31 PM   #15
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Makes sence, Ken. Its just all around so abusive to the motor. I didn't hook up the stuff because I know I'd use it...can't afford to blow this car up yet
What Stage 1 or 2 ? WRXctasy AccessPort 13 01-26-2007 10:08 AM
UTEC Launch Control Injector Cut-safe or not? SleeperWRX Engine Management & Tuning 14 12-29-2003 01:03 PM
Utec launch control tried out on my 03 wagon IA Performance Engine Management & Tuning 20 03-19-2003 07:07 PM
UTEC launch control in full effect. Opinions within IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 56 03-13-2003 07:46 PM
UTEC Launch control rev limiter? Typhoon Engine Management & Tuning 6 01-28-2003 09:08 PM
