Old 04-30-2005, 11:11 AM   #1
wrex03
Member#: 29963
04 sti
Default How to get rid of shift knock.
How do you get rid of shift Knock? I'll post a log either today, or monday.
The only way I'm not getting any is if I gradually release on the gas before a shift. If I just let of and shift, I get knock during very aggressive driving.
wrex03 is offline   Reply With Quote
Old 04-30-2005, 12:59 PM   #2
codean
Member#: 10186
Slip the clutch into the next gear, don't just drop the clutch. Also get all of the STI group N mounts for your car.
codean is offline   Reply With Quote
Old 04-30-2005, 01:20 PM   #3
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
you could do that.......
or just add a little fuel in the 0% TPS column
LatentWagen is offline   Reply With Quote
Old 04-30-2005, 01:50 PM   #4
happasaiyan
Member#: 37731
check out the timing in the 0 column...
Code:
Timing Map
   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
   [-100]   [-100]     [32]     [22]     [19]     [16]     [14]     [13]     [13]     [13]     [13]
   [-100]   [-100]     [32]     [22]     [19]     [16]   [14.5]   [13.5]     [13]     [13]     [13]
   [-100]   [-100]     [33]     [23]     [19]     [16]     [15]     [14]     [13]     [13]     [13]
   [-100]   [-100]     [32]     [23]     [19]   [16.5]     [16]   [14.5]     [13]     [13]     [13]
   [-100]   [-100]     [32]     [23]   [19.5]     [17]     [16]   [14.5]   [13.5]   [13.5]   [13.5]
   [-100]   [-100]     [31]     [23]     [20]   [17.5]     [16]     [15]     [14]     [14]     [14]
   [-100]   [-100]     [31]     [23]   [20.5]     [18]   [16.5]     [15]     [14]     [14]     [14]
   [-100]   [-100]     [30]     [23]     [21]   [18.5]   [16.5]     [15]     [14]     [14]     [14]
   [-100]   [-100]     [30]     [24]     [22]   [18.5]   [16.5]   [15.5]   [14.5]   [14.5]   [14.5]
   [-100]   [-100]     [29]     [24]     [22]     [19]     [17]   [15.5]   [14.5]   [14.5]   [14.5]
   [-100]   [-100]     [27]     [24]     [22]     [19]   [17.5]     [16]     [15]     [15]     [15]
     [19]     [19]     [25]     [24]     [22]     [19]     [18]   [16.5]   [15.5]   [15.5]   [15.5]
     [19]     [19]     [19]     [23]     [22]   [19.5]   [18.5]     [17]     [16]     [16]     [16]
     [19]     [19]     [19]     [22]     [22]   [19.5]   [18.5]   [17.5]   [16.5]   [16.5]   [16.5]
     [19]     [19]     [19]     [22]     [22]     [20]     [19]     [18]     [17]     [17]     [17]
     [20]     [20]     [20]     [22]     [22]     [21]     [20]     [19]     [18]     [18]     [18]
     [21]     [21]     [21]     [22]     [22]     [22]     [21]     [20]     [19]     [19]     [19]
happasaiyan is offline   Reply With Quote
Old 04-30-2005, 01:59 PM   #5
MMBOOST
Member#: 24140
02 Impreza WRX
http://www.logmapper.com
The proper way to get rid of shift knock is to put aroun 18 deg adv from around 4500 to redline in the 0 column. Its not a fueling problem, and here's why that's the case nd why the timing solution works:
You are going balls out, in the 90% or 100% column, revs are way up and you're pushing about 20+ degrees timing at around 7000 rpm, and then you shift. In an instant boost turns into vacuum and the UTEC moves into the 0% load column. So, in an instant you go from balls out timing to the timing that you have in there now or that the ECU provides (if you've letf it at 0). The problem is that this shift in timing is a drastic change in timing. This usually does, produce knock.
If you recall the "rule" that when you modify timing values you're support to interpolate the loadsites around it so that transitions in timing between loadsite are smooth, this is the same principle. The difference is, instead of a linear climb in load and RPMs, you're "wrapping around" from the 90/%100% to the 0% column via a
[edit] I just saw the map that was posted before I was able to finish my post. I should point out that he's running more than the 18 degress that I recommend... I didn't mean 18 has a hard and fast rule. It has to be commensurate with the timing you are running up top. You just want it to be close... and not just to the high load numbers but to the number in yoru 10% column too. Its tricky, soetimes. Although I think it needs to more similar to 10%-30% load columns at RPM ranges 1000-3000 RPM lower becaue after you shift and get back on the throttle, that's where you'll be [email protected]%.[/edit]
MMBOOST is offline   Reply With Quote
Old 04-30-2005, 02:50 PM   #6
hippy
Member#: 36528
2002 Impreza Wrx
Hey happ, your lower load columns at higher rpms look to me like they have abnormally retarded timing in them. Ie- as far as I know, there's no reason to have more retarded timing in the 0-20% columns compared to any of the higher columns at the same rpm ranges. Ya might wanna just copy the 30% load column over to the 0-20 where the values in the 0-20 are lower then the 30.
peace
Old 04-30-2005, 03:47 PM   #7
LatentWagen
Member#: 50315
interesting... i was told that it could be fixed with a little fuel (.5 or so) in the 0 column. that, and it completely fixed my shift knock
Old 04-30-2005, 04:46 PM   #8
wrex03
Member#: 29963
04 sti
Right after I posted I tried exactly what you stated, but I did 19 as that seemed to match up to the next load site after a shift.
Old 04-30-2005, 05:10 PM   #9
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
I'll make it easier dave, post a log of the knock and I'll tell you exactly what to do heh
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 04-30-2005, 08:01 PM   #10
happasaiyan
Member#: 37731
peace
no arguments here. i never hit those load sites (lower load, high rpm), so i never bothered to optimize them...so i just matched them to the 0 load column just in case it hit those load sites on the way down (to avoid shift knock). probably doesnt, but since i never hit those load sites, i didnt really care. thanks for looking out, though
Old 04-30-2005, 10:12 PM   #11
MMBOOST
Member#: 24140
02 Impreza WRX
happ,
you wont hit shift knock there. If you're not robbing yourself of power, at best you're preventing what I affectionally call "mash knock". (I.e. knock that happens right after you mash on the throttle after a shift, after you'd be expecting shift knock to occur. I'm sure hippy's right though.
jason
Old 04-30-2005, 10:36 PM   #12
LatentWagen
Member#: 50315
yea, whats the deal with mash knock. in second gear it happens often, and really slows me down.
Old 04-30-2005, 10:54 PM   #13
MMBOOST
Member#: 24140
02 Impreza WRX
You can think of mash knock as regular ol' WOT knock that happens down load. Its generally toomuch knock at [email protected] loadsites. Look on WRXhackers.com. There's a lot of stuff about mash knock on there.
Old 05-01-2005, 07:40 PM   #14
MattSTi
Member#: 54885
2004 PSM STi
2006 Mazda MX-5 Race Car
I added 18 degrees in my 0% column after experiencing shift knock, cured it right away.
-matt
MattSTi is offline   Reply With Quote
Dogs getting harassed by birds in backyard. How to get rid of birds? MyOtherRideIsUrMom Off-Topic 85 06-11-2010 12:46 AM
How to get rid of random/intermittent knock? Phatron Commercial ECU Reflashes 18 11-19-2007 05:53 PM
how to get rid of haze on the inside of a windsheild!??!? shipjumper Off-Topic 61 09-27-2005 07:42 AM
Do the 2005s get boost creep? If so, how to get rid of it? Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 09-09-2004 07:13 PM
('93-'01) pms!!! okay i need to know how to get rid of these. bratmantlz Impreza Forum 36 10-26-2001 09:50 PM
