Old 04-30-2005, 05:14 PM   #1
gmanwrx
Member#: 53871
95 s14 240sx
ruby red
Default boost creep? need help
need some help, i believe i"m having boost creep. my factory egt sensor took a ****. So i replaced it whit a 2.2 ohm resitor. Now in different gears i hit different boost levels instead of 20lbs all the time. i have a new factory sensor coming. but it just started after the sensor went. is that boost creep.
gmanwrx is offline   Reply With Quote
Old 04-30-2005, 06:08 PM   #2
2phless
Member#: 69343
1998 TransAm cnvrtbl
Not the right forum. If you hit 20psi before this issue began, I think you should post your mods, along with specific boost levels at specific RPMs, along with this thread... in the 2.0 forum. (Try 'search' too, they'll eat you alive if it's a common problem.)
I don't know about all the 2.5 motors but I don't have an EGT anywhere from the factory.
2phless is offline   Reply With Quote
Old 04-30-2005, 06:42 PM   #3
cabe
Member#: 55864
2002 WRX sedan
No, this is the right forum. What are your mods and what em are you using?
cabe is offline   Reply With Quote
Old 04-30-2005, 07:21 PM   #4
electricpork
Member#: 9498
03 Bugeye
Junkyards are fun!
http://forums.nasioc.com/forums/showthread.php?t=694714
Uh oh! Don't let Davenow see this thread!
Edit: On second thought, that depends on whether you are actually getting creep or not. Boost creep occurs when you don't have enough exhaust bypassing the turbo housing, so let's say you're set for 20 psi and you bring the car to WOT - the car will reach its target boost, but then as engine speed climbs, so will your boost. You've reached the limit of your wastegate's ability to bleed off pressure. If this is what is going on and you wish to tune it out, refer to above thread - if not, then by all means, keep posting. Without more information, its hard to say.
electricpork is offline   Reply With Quote
Boost Creep...Please Help Blacked out STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 01-03-2008 12:16 PM
Boost problem - need help Egan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-09-2003 06:35 PM
Boost Issues, Need Help kdawg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-08-2002 04:25 PM
Looking for electronic type boost controller. Need help with selecting? Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 05-19-2002 03:32 PM
Anyone with SBC-id and PM-id use the RPM Boost function?? Need Help!! smiles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-16-2002 11:20 AM
