04-30-2005, 04:17 PM | #1 |
Member#: 70470
Vehicle:2004 Impreza WRX aspen white |
Cel Wont Stop Flashing
i have a 04 wrx. my mods are: invidia dp, gt spec uppipe, hks catback, txs utec stage 2.5.
out of nowhere, my utec started acting up. i thought it might have been defective, so i unplugged it and plugged in the factory ecu. now the CEL wont stop flashing. and when i plugged my utec back in....it blinks A WHOLE LOTTA TIMES. does anybody know how i can fix this, or know the problem? thanks
04-30-2005, 04:40 PM | #2 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
does the car run ok on the factory ecu?
05-01-2005, 12:26 AM | #3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Are the two green plugs under the driver side dash connected? If so that is your problem and you must disconnect them, they should be hanging loose and will cause a constant flashing CEL if plugged together (among other things).
05-01-2005, 12:45 AM | #4 | ||
Member#: 70470
05-01-2005, 12:50 AM | #5 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
Green plugs disco'd all the time......
05-01-2005, 10:45 PM | #6 |
Member#: 69343
South East
Vehicle:1998 TransAm cnvrtbl Black |
Try just disconnecting the battery and clearing the code?
05-02-2005, 04:05 AM | #7 |
Member#: 38825
SCIC
unplug the battery and hold the brake for 30 sec. this will clear the computer of everthing.
if the green plugs are conected the cel light will flash, and the fans will keep turning on and off travis |
05-03-2005, 08:02 AM | #8 | |
Member#: 70470
05-03-2005, 08:54 AM | #9 |
Trust no one
This happens a lot, don't feel bad. Very often someone will be working under there and see those plugs hanging, and connect them assuming they are supposed to be connected. The result is usually a "what's wrong with my car?" post like this one.
Alarm wont stop going off, car wont start!! | felixk | Car Audio, Video & Security | 3 | 08-20-2009 05:10 PM |
99rs, lights wont stop flashing when car is off | KevinG | Electrical & Lighting | 4 | 02-09-2008 10:29 PM |
CEL One Single Flash, not continious flash | NITROS | UTEC | 5 | 12-23-2006 07:19 AM |
2 CELs, GAS Smell, Flashing CEL, HELP! | Zerolapse | Service & Maintenance | 1 | 09-15-2006 10:50 PM |
Car wont stop dying! | RocketFuel | Service & Maintenance | 10 | 06-09-2003 10:59 PM |
