Old 04-30-2005, 04:19 PM   #1
99WRXEJ20
Member#: 34545
1999 GC8
74f
Default Oil leak but dont know where! ej20g
have an ej20g swap and i seem to be burning oil somewhere, cause i can smell it when my car sits after running and at red lights. There is no smoke coming out the exhaust or in the engine bay. I am down about 1/2-3/4 quart for every 30-50 miles. I had the timing belt and oil pump seals done about 10K ago, but not totaly ruleing that out. When I had that problem before you could see and hear oil hit the exhaust manifold and thats not happening this time. Motor has about 75k on it and I just got a tune and turned up the boost for 12.5psi to 16.5.
I am going to see if it might be the rear main seal today but anyone have any other suggestion?
thanks
99WRXEJ20 is offline   Reply With Quote
Old 04-30-2005, 08:13 PM   #2
snowjob
Member#: 59357
2009 Forester XT
put a peice of carboard under it overnight, in the morning you will see where the splatter marks, if any are, and be able to tell where to look.
Good luck.
snowjob is offline   Reply With Quote
Old 04-30-2005, 09:54 PM   #3
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Is the turbo whining??? My turbo started whining last summer and then my oil consumption went up. I had no apparent shaft play but there was oil in the intake tract. I'd say turn the boost down a bit until you figure it out.
That's a LOT of oil to be using every 30-50 miles.
GL sorting it out.
-mykr.
mykrrrr is offline   Reply With Quote
Old 05-01-2005, 07:14 PM   #4
bugman1964
Member#: 57667
01 gm6 rs brp
SXS performance
i would also double check the oil level sender on the top of the block behind the alternator
bugman1964 is offline   Reply With Quote
Old 05-02-2005, 10:56 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
With that kind of consumption, it sounds like bad crank bearings, but no tailpipe smokes makes that seem unlikely. However, when I had bad bearings a few months ago, I didn't have very much tail pipe smoke once the car warmed up. But my oil consumption was about the same. When I got the block out and torn down, I had 3 spun bearings and most of the crank and rod bearings were scorched.
I doubt it is the rear main if you aren't seeing oil drip between the tranny and the engine. If it is leaking that bad, you will be pooling. Personally, from what you have said, I think you are burning it off internally. Do you have an oil pressure gauge? That is a key instrument on a turbo car...
03 oil leak dont know where??? crash60068 Forester Forum 4 01-13-2010 06:52 PM
looking to gain more power, but dont know where to turn mikeyp973 Built Motor Discussion 17 12-09-2008 11:24 AM
Help want to go to scooby meets but dont know where or when scoobymuff South West Impreza Club Forum -- SWIC 11 03-27-2008 07:39 PM
Need to get a part, but dont know where to start? jersey1320guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-07-2008 06:48 PM
Extreme boost leak...but dont know where NewGwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 10-16-2006 09:05 PM
