Old 04-30-2005, 06:33 PM   #1
deluxsti
Member#: 84313
04 Aspen STi
Default em options
i have the cobb street tuner and it has been nothing but a headache for me. i am going to just take the acessport and street tuner back and start over. is there anything besides turboxs utec for an 04 sti? i want something that will not have 1000 diff. problems and pretty much plug and play.
deluxsti is offline   Reply With Quote
Old 04-30-2005, 06:44 PM   #2
HonduHunter
Member#: 28408
2002 vf48ed WRX
why has it been such a headache?
HonduHunter is offline   Reply With Quote
Old 05-01-2005, 06:53 PM   #3
deluxsti
Member#: 84313
04 Aspen STi
its not responding to hte software at all, stuck at 11.02 air fuel and cobb cant help me
Old 05-02-2005, 08:31 PM   #4
shinsain
Member#: 51745
LIKE A
BOSS
What have they said, just out of question? It seems that they should. Maybe you have a faulty piece of hardware, or a setting wrong with the ST software?? Just random thoughts...
shinsain is offline   Reply With Quote
Old 05-02-2005, 09:38 PM   #5
hondaeater69
Member#: 60324
ECUtek
Old 05-03-2005, 12:43 AM   #6
deluxsti
Member#: 84313
04 Aspen STi
they didnt know what to do so they had me post the prob. on their forum and no help at all.
Old 05-03-2005, 01:22 AM   #7
trymyrex21
Member#: 45638
WRX 12.9 1/4
now a [email protected] AUTO
ecutek get if flashed for your setup and put it in, ive had no problems with ecutek.
trymyrex21 is offline   Reply With Quote
Old 05-03-2005, 04:06 AM   #8
bboy
Member#: 56468
04 Improved STI
Dirty White
EcuTek. I like PDX Tuning's reflashes. Call and talk to Tim Bailey he's a great tuner of Subys
Old 05-03-2005, 06:48 AM   #9
happasaiyan
Member#: 37731
well, they did respond to your question...
...the problem you describe is from an older software version. i had the same problem, but it was fixed in the first software update.
...and you cant trust the stock O2 sensor for accurate readings too far outside of stoich. 11.02 is the richest reading the stock sensor will give. if you want accurate readings, you need an external WBO2 sensor...like an LM-1
happasaiyan is offline   Reply With Quote
Old 05-03-2005, 11:37 AM   #10
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Ok, so Cobb should somehow be able to read people's minds? Of course you have to explain the problem.
Secondly, there is a post in response to your thread that was posted late last night.
Finally, you look to be using the stock O2 sensor for your air/fuel readings. Let me show you the problem with doing that; this was taken from a log I did last night:
Code:
Engine RPM	A/F Ratio	Engine Load	LM1-A/F Ratio
3443	12.98	1.15	13.377
3561	12.4	1.22	13.038899
3561	12.4	1.22	12.6126
3640	12.29	1.28	13.009501
3740	11.6	1.34	12.8331
3740	11.6	1.34	12.7008
3844	11.6	1.39	12.6126
3955	11.37	1.42	12.5391
3955	11.37	1.42	12.4656
4016	11.48	1.45	12.4362
4016	11.48	1.45	12.4803
4175	11.48	1.47	12.3039
4278	11.02	1.51	12.2745
4278	11.02	1.51	12.0393
4414	11.02	1.52	11.6424
4515	11.02	1.51	11.6424
4515	11.02	1.51	11.6571
4606	11.02	1.51	11.6424
4783	11.02	1.51	11.5983
4783	11.02	1.51	11.5689
4866	11.02	1.53	11.510099
5009	11.02	1.56	11.510099
5009	11.02	1.56	11.4072
5143	11.02	1.56	11.2749
5219	11.02	1.58	11.172
5334	11.02	1.58	11.2455
5466	11.02	1.6	11.2308
5466	11.02	1.6	11.304299
5567	11.02	1.61	11.304299
5681	11.02	1.61	11.2749
5681	11.02	1.61	11.3631
5822	11.02	1.62	11.4366
5928	11.02	1.62	11.4219
5928	11.02	1.62	11.4072
5952	11.02	1.61	11.4219
6072	11.02	1.61	11.3925
6072	11.02	1.61	11.4513
6172	11.02	1.6	11.4513
6329	11.02	1.6	11.4219
6329	11.02	1.6	11.495399
6366	11.02	1.59	11.5836
6476	11.02	1.59	11.5983
6642	11.02	1.58	11.554199
6642	11.02	1.58	11.4366
6756	11.02	1.57	11.4513
6805	11.02	1.56	11.3925
6805	11.02	1.56	11.3778
6918	11.02	1.53	11.3925
7022	11.02	1.5	11.4072
7022	11.02	1.5	11.3484
7108	11.02	1.48	11.3925
7218	11.02	1.45	11.3778
7218	11.02	1.45	11.3484
7253	11.02	1.43	11.3925
7374	11.02	1.41	11.554199
7455	11.02	1.4	11.5395
7455	11.02	1.4	11.5836
7530	11.02	1.39	11.6571
7621	11.02	1.37	11.5395
7621	11.02	1.37	11.671801
7739	11.02	1.36	11.7012
7739	11.02	1.36	11.6277
7804	11.02	1.35	11.613001
7902	11.02	1.34	11.613001
7902	11.02	1.34	11.6865
The stock O2 sernsor is consistantly around .5 points off at any given spot. I sure as hell wouldn't want to tune with it.
-Jon
Old 05-03-2005, 09:15 PM   #11
deluxsti
Member#: 84313
04 Aspen STi
i just ordered an innovate lm-1, but im still not hitting target boost, i have the stiffest spring that power enterprises makes for the wastegate actuator and i want 23 psi, but stuck at 18.42, never any higher than that.
95L with v2/ v3 WRx motor EM options darkspyderxx Subaru Conversions 14 12-10-2006 02:27 AM
EM options for a 2005 RS??? Davenow Normally Aspirated Powertrain 11 10-27-2005 06:31 PM
EM options/products for 1999 OBS (any? any at all?) kaisersouse Engine Management & Tuning 0 06-30-2005 08:43 PM
I don't like any EM options yet for my STI VR62STI Engine Management & Tuning 30 06-15-2005 03:56 PM
Vishnu Xede, and other EM options steve Vancouver Impreza Club Forum -- VIC 15 10-28-2004 01:04 AM
