Old 05-01-2005, 04:47 AM   #1
manman99
Member#: 51343
Smile UTEC with Octane 98
Hi,
I am from Singapore and thinking of using utec for my wrx.
Here we have high octane fuel of 98, if I buy the utec
a. does it come with any map ?
b. cann we request for stage 1, 2 , 3 and 4 map
c. since the map for all the stages is Octane 93,
will I have problem running this map with Oct 98 fuel?
d. What is the parameters that i need to modify to
run on Oct 98 fuel?
e. If I am using stock ecu and run STI injectors, will
it cause any problems?
Thks
Rgds
lam
manman99 is offline   Reply With Quote
Old 05-01-2005, 10:26 AM   #2
hippy
Member#: 36528
2002 Impreza Wrx
You could probably run a 93 octane map with 98 octane and not have any problems. If you really get 98 octane, you could probably up the boost a bit, add some timing, and remove some fuel to take advantage of the higher octane. From what I hear though, there's a difference between 98 octane in the states and what many people get in other places when they think they're getting 98 octane. Ie- in places like europe the 98 could mean 98ron(from what I hear) which is kinda if not totally equivolent to the 93 octane we use in the states, not the what 98 octane would be in the states. If you're getting 98 ron, there would deginately be much optimitation available(timing advance, more boost, and leaner a/f ratio) before you start running into problems.
peace
Old 05-01-2005, 11:18 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
You will need a different UTEC than we get in the USA....there is an Australian version that will work with your car, I believe....the USA one won't, I don't think.
contact TXS, australia...and ask them
Old 05-01-2005, 01:29 PM   #4
Timdog1650
Member#: 45516
MY04 STi
98 asian gas = 94 USA gas.
When you order from a vendor, they should be able to get whatever map you want pre-loaded when they get their shipments from TXS
Timdog1650 is offline   Reply With Quote
Old 05-02-2005, 01:25 AM   #5
manman99
Member#: 51343
Hi Guys,
Thks for the reply...some more questions
1. how many maps we get when we buy a brand new utec?
2. is the remote map selector included in the package?
3. can we do the map switching when car is on the move?
4. is the UTEC running on 16 or 32 bit?
5. if ruunng stock ecu with STI injectors, is there any problem?
6. does the utec has any dyno chart that can be generated?
Thks
Rgds
lam
Old 05-02-2005, 09:19 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
1....up to 4
2....no
3....yes, under 1500rpm
4....dunno
5....not for the USDM version
6....no
see....
http://www.turboxs.com/
....and because your car is NOT USDM spec, what you need to buy may be a bit different than what we get....unnastand????
TX: JDM projector headlights with harness, Kaminari hood, TXS UTEC with map selector djcttb Private 'For Sale' Classifieds 61 09-27-2005 08:47 PM
sighting: wrecked rally blue GC8 with gold 98-99 rims yeng Vancouver Impreza Club Forum -- VIC 1 01-15-2004 02:37 AM
HELP! I need to interface with my UTEC with Mac OSX Capt Crunch Engine Management & Tuning 1 06-22-2003 07:27 PM
Looking for a Claude C. with a 98 blue RS that used to be in Sping Valley soybeanz Tri-State Area Forum 1 03-01-2003 09:51 AM
Random Technology cat with an 98 L baldcherub Normally Aspirated Powertrain 7 03-02-2002 04:29 PM
