05-01-2005, 03:00 PM | #1 |
Member#: 37059
Vehicle:03 WRX World Rally Blue |
how to wire HIDs to EDM headlights?
how did you guys wire your hids to your edms? Did you guys use the existing predrilled hole in the dust cap and just make it bigger, or did you guys drill another hole in the dustcap?
I used the pre-existing hole and drilled it bigger and fed the bulbs through with the bulb grommet sealing the hole. However, I snipped off the H1 connector so it doesn't have to go in the dustcap anymore and spliced that directly to one of the bulb wires that opiginally had an h1 spade connector. So basically I spliced the edm h1 wire to the h1 bulb wire on the OUTside of the headlights, not inside. Were you guys able to connect an hid kit to the edm without splicing anything and just connecting everything inside the dustcap?
05-01-2005, 03:05 PM | #2 |
Member#: 72106
NWIC
Vehicle:2002 Impreza WRXagon Platinum Silver Metallic |
I made a harness with 9007 bulb socket. jdmpartstx.com has some instruction on how to wire up the hid kit. Since you're isn't an HID kit, you don't have to ground any ballast to the body.
How to wire HID kit to edm projectors? | sjscooby | Electrical & Lighting | 11 | 05-07-2007 07:56 PM |
bugeyes JDM HID on EDM headlights | Caobay | Electrical & Lighting | 4 | 11-25-2005 10:04 AM |
Adding HID's to 02/03 JDM/EDM headlights | Uncle Ben | Electrical & Lighting | 2 | 10-02-2005 05:28 PM |
anyone know how the motors on the edm headlights work? | datdudedennis | Electrical & Lighting | 1 | 06-29-2005 10:49 PM |
OK to wire alt. to battery? | BLZ2DWL: | Car Audio, Video & Security | 2 | 10-20-2001 12:23 AM |
