Old 05-01-2005, 11:09 PM   #1
wrxxed
Member#: 20567
04 2014 Forester
Question AP -18.3 @ wot in 5th and 6th gears
Right after flooring it the boost hits 18.3psi on the AP for a second then tapers off. Is this considered a spike? No abnormal engine noise. Solutions? Thanks.
wrxxed is offline   Reply With Quote
Old 05-01-2005, 11:38 PM   #2
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
18.3psi is the max it will read. You should have a boost gauge to see what its really doing.
~v6
V6TurboTA is offline   Reply With Quote
Old 05-02-2005, 04:07 AM   #3
Jkonquer
Member#: 81058
05 impreza wrx sti
white/gold
what stage are you running?
stage1 and 2 on sti suppose to hit 17.5, if its higher or lower by .5 its fine
but in your case, you should run lwg
Jkonquer is offline   Reply With Quote
Old 05-02-2005, 11:30 AM   #4
03WREX
Member#: 38932
2003 WRX
WRB - Cobb Stg2
That seems really high. Did you just reset your ECU? It may be trying to learn and adjust but if not then I'd be careful going WOT with that kind of boost.
03WREX is offline   Reply With Quote
Old 05-02-2005, 01:21 PM   #5
ibis
Member#: 1132
Seems a little high....but if you are in 5th or 6th and around 2.5K rpm and flooring it to get around the grandma in front of you on the on ramp...then yeah....you will see that happen. You might want to downshift and try to keep it in the power band
Justin
COBB Tuning
ibis is offline   Reply With Quote
Old 05-02-2005, 09:06 PM   #6
wrxxed
Member#: 20567
04 2014 Forester
I actually flashed the 93 stg 2 in last friday. I was out test driving and wanted to check the boost levels and have some fun of coarse. So I took it on the hwy and @ 2500-3500 rpms I'd floor it to check for boost spikes and viola! Ap real time boost would shoot to 18.3(I am aware its the highest the AP will read)and quickly taper down. No abn engine noise. I assume the stock ecu will protect the engine if I'm overboosting correct. I mean thats the benefit of reflashing the OEM ECU that you keep the factory ecu protection??? Would you recommend trying lwg93?? Thanks to all who responded.
