05-02-2005, 02:29 PM | #1 |
Member#: 62182
NWIC
Vehicle:2005 STI White |
Defi Turbo gauge reading with engine off?
Mine reads a little below 0, does anyone know if this is normal? My sender is mounted a bit off from perfectly vertical, but I don't know if that would make a difference.
-Mike
05-02-2005, 03:32 PM | #2 |
Member#: 7922
Vehicle:04 CTS-V b/b/b 99 GMC Highrider |
As long as you know where "zero" is it's fine. Just add or subtract the little difference from your actual reading to get your true pressure.
05-02-2005, 03:40 PM | #3 |
Member#: 26067
SWIC
Vehicle:2012 Jetta Grey |
is the ignition on? cuz it should re-calibrate every time you turn in on...and it should read 0 psi
05-02-2005, 06:29 PM | #4 |
Member#: 62182
NWIC
That's with the key in the accessory position (that's where I pulled "ignition" power, I'll rewire it for proper ignition power at some other time).
I would expect a $200+ gauge to be able to read properly without having to do a mental calibration. -Mike |
defi boost gauge read wrong?? | davidsti1 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 22 | 10-26-2009 01:39 AM |
Defi boost gauge reading off | ardevas09 | Electrical & Lighting | 0 | 12-06-2008 07:18 PM |
Brakes firm with engine off, mushy with engine on | chimchimm5 | Brakes, Steering & Suspension | 58 | 04-16-2008 01:33 AM |
Defi egt gauge reading way off??? | bstoehr83 | Electrical & Lighting | 2 | 09-20-2007 02:01 PM |
Do all connectors for Defi Link gauges work with Defi BF gauges? | mav1c | Electrical & Lighting | 0 | 11-13-2006 02:38 PM |
