Old 05-02-2005, 05:03 PM   #1
MINO
Member#: 12841
Default Logging AFRs by cylinder:
I would like to log my AFRs by individual cylinders but the LM-1 states that the O2 should be placed post turbo for accuracy.
Has anyone tried to get readings pre-turbo and more specificly by cylinder?
What were your results.
Thanks.
MINO is offline   Reply With Quote
Old 05-02-2005, 06:07 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
A lot of the time the egt's are too hot before the turbo for the o2 sensor to opperate normally which is why the o2 sensor is supposed to be places after the turbo. It would probably be much less expensive to get a 4 way egt gauge and install an egt probe in each exhaust runner. If one is running hotter then another, you know that's the one ya need to add fuel to even if the a/f ratio is the same to start out.
peace
Old 05-02-2005, 06:37 PM   #3
hondaeater69
Member#: 60324
THere's a thread around here where a vendor (SMC) logged EGT's by cyclinder. He was going to do AFR's next but i don't think he ever got around to it. You can do four way AFR's, not sure I'd keep them in there permanently due to the temps, but they'll be fine short term. Remember there's an 02 sensor at the end of your manifold. If you log that sensor with a WB post turbo, you will get identical readings down to 11.25 (which is as low as the front stock 02 sensor goes down to). That sensor is in ALL of our cars, and will last a LONG time. If I had to choose between four way AFR's and four way EGT's, i would choose AFR's all day long.
Old 05-02-2005, 06:39 PM   #4
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
peace
mabey I am reading it wrong but how would you just add fuel to ONLY 1 cyl.
Mav
mavrick is offline   Reply With Quote
Old 05-02-2005, 06:52 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
The problem with wideband sensors pre-turbo was exhaust back pressure, at least with NTK wideband sensors. This is/was according to Garfield Willis, who passed away last year. His websites are dead now, too, but here's what he used to say, thanks to the Way Back Machine: http://web.archive.org/web/200310291...ield/index.htm. Check out the Products>EGORmedusa.
Jon [in CT] is offline   Reply With Quote
Old 05-02-2005, 06:53 PM   #6
hondaeater69
Member#: 60324
/\/\ it's called standalone EM
Old 05-02-2005, 08:29 PM   #7
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
I was thinking that just checking I didn't think Utec was being used
Old 05-02-2005, 08:39 PM   #8
hippy
Member#: 36528
2002 Impreza Wrx
Bosche wbo2 sensors have a built in heater circuit of some type which heats something in the sensor upto something like 1250F. If the exhaust gasses going though/past the sensor are hotter then 1250F, the sensor won't work accurately. This is why people put the sensor after the turbo. The exhaust gas temps after the turbo are cooler then b4 the turbo. Course everything I know is wrong, so beleive what you like.
peace
Old 05-03-2005, 03:15 AM   #9
bboy
Member#: 56468
04 Improved STI
Dirty White
I've got 4 EGT probes. That's the best you can do. The O2 sensor can't handle the heat. I've never posted my data. I'll do that soon. Basically, the differences vary across the RPM range so you can't really tune to keep consistant EGT at all load sites, but you can adjust the individual injectors for WOT EGT variation so that the "peak" EGT can be normalized. With a Hydra EMS from Element Tuning you can make individual adjustments, and also other stand alones, not so sure it's possible with EM systems.
BTW you'd be amazed at the difference in EGT between exhaust port and the up-pipe with headers. It's like 200-300 C cooler and my header are coated inside and out.
Stage 2 log. AFR occilation and slow boost? Brock31 Open Source Reflashes 12 10-06-2009 12:18 AM
'06 Stage 2 WRX, logged AFR not matching map targets wage0052 Open Source Reflashes 27 01-16-2008 06:43 PM
Target Log for AFR over RPM range plus plus plus UTEC 3 04-22-2007 07:38 PM
afr logs carl s. Engine Management & Tuning 8 01-02-2007 10:49 AM
Logging with EcuExplorer and AFR? bmw50021 AccessPort 3 10-17-2006 07:52 PM
